Pacer_ar wrote:I heard someone call it a poor man's Cessna 180 once. Seems like a pretty accurate description.
Geoffb wrote:At your elevations and field lengths, a pacer will do everything you're looking to do and then some. Actually, you want a PA-22/20 conversion. Wide Univair gear, more mods available.
braol wrote:Oh, and when did they come out with the metal spar that I read about in the Stewart wing-tip mod?
braol wrote:Geoffb wrote:At your elevations and field lengths, a pacer will do everything you're looking to do and then some. Actually, you want a PA-22/20 conversion. Wide Univair gear, more mods available.
is there any real difference value-wise/resale of a modded, regular PA-20 vs. making a 22 into a 20 with the tailwheel conversion?
Zzz wrote:Keep your trigger finger outside the guard until you find one that has the good stuff already done, otherwise you'll end up like me—misplaced optimism that results in your plane stripped down to bare fuselage, welding and grinding on it, cursing the guys with flying airplanes on a sunny day.
Battson wrote:Zzz wrote:Keep your trigger finger outside the guard until you find one that has the good stuff already done, otherwise you'll end up like me—misplaced optimism that results in your plane stripped down to bare fuselage, welding and grinding on it, cursing the guys with flying airplanes on a sunny day.
It sounds like you need a homebuilt project
