I'm seeing some arcing inside my KT76a transponder. It took weeks to track this down, originally hearing what I thought was a mechanical 'click' about once per hour when flying. That's a grand story in itself, but I finally caught the culprit on video, my KT76a arcing inside the shell. The transponder is fully functional, as per ATC telling me I'm transmitting to them. It's very occasional, not repeatable, etc. The GoPro was recording for 1.5 hours before it happened on this flight.
Has anyone seen this? the engineer in me want's to squirt some 50cents of RTV up there so insulate whatever is shorting out, but the rule-following pilot says that's probably a no-no.
Avionics shops want $110 to even set it on their bench. Used replacements $200-500.
Thoughts?
Thanks for any/all help. Not ready to spend $4-5k on ADS-B yet.
-asa
Video: (watch the holes in the bottom of the transponder. This view is look upwards from under the copilot side of the panel.
