Vick wrote:Lots of options for sure! I've been looking into the 3-bladed MT and like everything I've heard so far (except the price). I called flight resources in WI and asked lots of questions, I really like the sound of dropping 30 lbs off the nose and the stainless leading edge is supposed to really resist wear. Manufacturer claims and feedback from the field supports that the MT will out pull anything else. That with a bigger 520/550 on your plane would make a monster!
aktahoe1 wrote:So most of you know my plane, a 53 -180 ( If not, you can also see it on my blog...www.bigtirepilot.com) and I am considering getting a IO-550. Currently the plane has a 57 cowling on her.
Questions: Anyone have insight on the composite cowling from Selkirk?
Anyone know of a 57 cowling available or where I may find one...this is all assuming that is what I need per what I have been told. I need to be educated here please.
What cowling goes with the IO-550 for a 53 180? Currently running a 470K. Is it even possible? (stupid question)
What is your thoughts on the best prop out there? I really like the McCauley 3 blade. Currently running the 88" 2 blade sea plane prop.
Calling Texas Skyways now and Selkirk but curious of your thoughts please.
Thanks
Kevin
182 STOL driver wrote: Expect to use more fuel (fuel /air ratio) per hour for same rpm .Increase power /increase fuel consumption over 470.
aktahoe1 wrote:..... My 470 already has 520 jugs giving me 260 I believe. Its just that time to make it happen. Seems like a lot of options. Just want to make the correct choice......
hotrod150 wrote:aktahoe1 wrote:..... My 470 already has 520 jugs giving me 260 I believe. Its just that time to make it happen. Seems like a lot of options. Just want to make the correct choice......
So is it a 520 then? (aka 470+50 Ponk)? Curious why you want more displacement-- do you run out of steam now, or is it just a case of "bigger is better"? It sounds like you're pretty pleased with your airplane as it currently sits-- I'd make sure that any upgrade doesn't ruin the light handling you enjoy now.
My airplane WAS perfect...
aktahoe1 wrote:Lets just say that this need has come sooner than expected...My airplane WAS perfect...
low rider wrote::-#
Zane wrote:Brother man, I feel like you're Mikey from the Life cereal ads that were on TV when we were kids...
