CamTom12 wrote:Also, for the record, graphite is a conductor. So if you're using the appropriate anti-seize it should not be dielectric.
Sent from my LG-D850 using Tapatalk
…. sigh…
The waters are getting convoluted
Here's some records for you ;
Resistivity and
conductivity are
reciprocals. In a conversation such as this, bringing up conductivity without addressing resistance nets very little, and nothing absolute
My initial post on this thread were solely based on the
resistance I found in Champ plugs. My follow up was based on the added
resistance of reusing impure gaskets.
The graphite in (Champion) anti seize is utilized for it's lubricating properties, the fact that it's a
conductor is just an added (relatively cheap) bonus. While it is indeed true that graphite (Carbon) is a
conductor, it's
resistance is something on the order of 1000 times that of annealed copper, let alone pure bare copper. You can probably find a chart on the net, if you want the exact numbers as I'm not that sharp, but I'm 100% positive the difference is MASSIVE (no pun intended). In fact if conducting electricity to the plug was the goal, even iron would have been a better choice (based on resistance) than graphite.That is what I was alluding to here;
Rob wrote:... but are you talking about the same threads the vast majority apply a resistant anti seize to? That path is going to be determined by resistance, just like the throttle cables that get fried because the ground strap is bad...
Take care, Rob
and all of this is not too far away from why you can't take your GA headset and run it in your work bird (military vs GA impedance) while they both conduct just fine
One last time, I would anneal a gasket in a pinch, and agree we are splitting hairs, but the bottom line is (at least for me) there is value in splitting these hairs.
A short story
Several years back our chief pilot poo-pooed the vgs on my Thrush. His exact wording fails me now, but I believe it was something like 'how can a few 1/4" pieces of aluminum do anything remotely detectable in that 60' cantankerous wing'… As it was I was wrenching on something and had a set of dikes in my mitt, so I casually walked over and sized up the dikes to a VG. I then walked over to his airplane, grabbed on to his aileron trim tab approximately as deep into the dikes as to simulate a VG, and gave it a 1/4" tweak
OMG! he just about shit a purple twinkie… sideways…
Dan ; "Now why'd you go and do that! I'm going to have to get out a half dozen times for the next half dozen loads to get the old girl flying straight again"….
Rob: "Now Dan, surely one little 1/4" tweak to your trim tab can't possibly make a difference? after all, the 150 1/4" little VG's scattered across my wing don't "
A year or two later Dan and I are in Iowa for our summer gig, and haven't the luxury of a pressure washer in the barn. One morning Dan notices that every morning I get the rag I left in the grass the night before and use the dew to wipe off all the oil and aphids that accumulated on my leading edges the day before. In front of the fellas he gives me quite the ribbing… and I am OK with it.. but at dinner that night he asks what the deal is, after all it's not like I am washing down the airplane, just the LE and the prop. So I share that I once watched a video of a tufted wing at the stall, and in that vid it was very interesting (to me) for quite a bit before the increasing AOA approaching the stall, how little of the wing was actually flying. In fact it was only about the front 10" or so of the wing that was even doing anything at all
the rest was very obviously just there for the ride. Consequently it was apparent to my feeble mind just how important a good LE was. After watching that vid, I religiously started cleaning the LE of my work plane before every day / night, and at least to me the difference was clearly noticeable.
Needless to say, the next day Dan was out wiping down the LE of his wing during his preflight, and it wasn't a day or two more before everyone else on the line jumped right in… Every year since then, we get a new pilot. As a general rule they don't show up with this habit, but also as a general rule they all leave with it.
Little differences… Some do some don't
and also for the record, I wasn't trying to be argumentative, just sharing my thoughts, please feel free to disregard anything that doesn't make sense to you, it's exactly what I do when I read something that doesn't jibe to me.
Take care, Rob
