WTB-Cleveland brake takeoffs
Gear for sale, gear wanted, etc. Be sure to read the
Required Reading sticky before posting.
Mon Oct 09, 2023 10:17 am
Shop says I need new calipers. “ LH brake caliper is seeping fluid from corrosion pores around upper fitting.”
“ RH brake caliper is still leaking out of puck Oring due to the heavy pitting in the bore” They don’t think the calipers are reparable. Cessna part number 163030-113
I want to stick with the Cleveland’s. Does anyone have takeoffs after moving up to double pucks for big tires?
PNW Flyer offline
245
- Aircraft: C182P
I just did the conversion to double puck brakes….out of country u til the weekend Will check parts numbers over the weekend…..brakes were great…just wanted doubles
Airdave100 offline
126
- Aircraft: 1956 Cessna 182....N5632B
Pretty sure I have a pair of those at the shop. Give me a call tomorrow 720-220-8969
Tony
AEROPOD offline
492
Are you still looking for calipers…finally got back home and have unpacked….sorry it took so long….DP
Airdave100 offline
126
You don’t know what you don’t know. Reading the correct document or reading the document correctly isn’t that easy when it comes to brakes. Turns out ours are McCauleys, not Cleveland’s. But you cannot buy McCauleys. Cessna service bulletin SEB00-5 says use Cleveland’s to replace the McCauleys by getting a field approval. Cleveland conversion STC doesn’t cover the P model 182.
Long story short ABI 199-62 conversion kit to double puck brakes (with wheels) is the most practical solution and includes the necessary Atlee Dodge STC. And is cheaper than either single or double puck Clevelands.
PNW Flyer offline
245
- Aircraft: C182P
Well….on the other hand you got double pucks…..you’ll like them…..DP
Airdave100 offline
126
Sun Dec 03, 2023 11:53 am
Have a set of Cleveland single puck brakes removed from a ‘56 182 for upgrade to double…along with a set of solid aluminum axels….pucks are at least 3/4 remaining….I’ll take an offer on the package or individual…..
Airdave100 offline
126
Sun Dec 03, 2023 10:03 pm
We just tried to convert a 182 using 199-62 Airframes kit. They will not work with wheel pants according to airframes and verified in the field.
I think the Cleveland 199-84 kit is the substitute for McCauley.
Masterbaler offline
7
- Aircraft: Cessna T210M
Piper PA-12
Turbo commander 840-10
Piper PA28-180
Cessna A185E
