denalipilot wrote:Just thinking out loud here: How would it go if they pulled off all the gear and towed it on its belly with a long enough rope/ strap/ cable? Get a few folds of plastic sheeting under the belly and wet down the grass with some pails of water from the creek for good measure? Or is the ground too squishy right now?
Super-Maule wrote:denalipilot wrote:Just thinking out loud here: How would it go if they pulled off all the gear and towed it on its belly with a long enough rope/ strap/ cable? Get a few folds of plastic sheeting under the belly and wet down the grass with some pails of water from the creek for good measure? Or is the ground too squishy right now?
Denalipilot,
The nose gear is detached from the firewall, but the main gear is OK. A few sheets of plywood leading to a tilt-bed car hauler trailer, would work the best. I don't know what the crew will show up with. If a wrecker is required the airplane will definitely suffer. Those wings are interchangeable with a Cessna 180, about 6K a piece.
James
, (or the diplomacy stuff,
) but a good engineering challenge is hard to stay away from. Good luck!
Terry wrote:The reason I like Idaho and Eastern Oregon so much is its a small world there.
People are friendly, helpful, and wave when you drive by.
I say give the guy a good ass chewing, dive in and help him get his airplane out of there.
But maybe your gut feeling is telling you otherwise?
I hope he doesn't give you anymore problems.
scottf wrote:Terry wrote:The reason I like Idaho and Eastern Oregon so much is its a small world there.
You think like I do. We can't let lawyers or the threat of them determine how we live and how we treat people, otherwise we live in a society that isn't much fun to live in.
shortfielder wrote:Would it be more clear if X's were on the strip, and those invited/w/permission could disregard the x's and land, and others would know they were not wanted there, or does that open up other complications.
Gary
Cary wrote:This whole question of airstrip owner liability, since that was a sub-thread in many of the comments, isn't easy to answer. In some states (again remembering that I'm not conversant in Idaho law), a trespasser isn't protected and has no claim at all against a landowner, but if that person is a licensee or invitee, there is some responsibility. The usual question is to differentiate between trespassers, licensees, and invitees, by defining who they are and what duty is owed to them. In others, however, the landowner has some responsibility to make his property safe, at least to the extent of not having some overtly dangerous situation there (open mineshafts without any warning signs and barrier fences are a classic example) for anyone who comes on the property. I have no idea where Idaho law stands on this, and I'll bet that without doing up to date research, even Idaho attorneys would disagree. And that research has to be up to date.
Bonanza Man wrote:Cary wrote:This whole question of airstrip owner liability, since that was a sub-thread in many of the comments, isn't easy to answer. In some states (again remembering that I'm not conversant in Idaho law), a trespasser isn't protected and has no claim at all against a landowner, but if that person is a licensee or invitee, there is some responsibility. The usual question is to differentiate between trespassers, licensees, and invitees, by defining who they are and what duty is owed to them. In others, however, the landowner has some responsibility to make his property safe, at least to the extent of not having some overtly dangerous situation there (open mineshafts without any warning signs and barrier fences are a classic example) for anyone who comes on the property. I have no idea where Idaho law stands on this, and I'll bet that without doing up to date research, even Idaho attorneys would disagree. And that research has to be up to date.
Neither of your above examples is correct. Here's the relevant info from Idaho law.
(c) Owner Exempt from Warning. An owner
of land owes no duty of care to keep the
premises
safe for entry by others for recreational purpos
es, or to give any warning of a dangerous
condition, use,
structure, or activity on such premises to
persons entering for such purposes. Neither the
installation of
a sign or other form of warning of a danger
ous condition, use, structure, or activity, nor
any
modification made for the purpose of improving
the safety of others, nor the failure to
maintain or keep
in place any sign, other form of warning, or
modification made to improve safety, shall
create liability
on the part of an owner of land where th
ere is no other basis for such liability.
(d) Owner Assumes No Liability. An owner of
land or equipment who either directly or
indirectly invites or permits without ch
arge any person to use such property for
recreational purposes does not thereby:
1. Extend any assurance that the pr
emises are safe for any purpose.
2. Confer upon such person the legal stat
us of an invitee or licensee to
whom a duty of care is owed.
3. Assume responsibility for or incur lia
bility for any inju
ry to person or
property caused by an act of
omission of such persons.
Colorado has not yet added aviation to their RUS but it is currently being worked on.
