Mapleflt wrote:My SOP is a carb heat function check along with mags during every runup be it on wheels or float, regardless of season or current atmospheric conditions
Might as well remove the fuel gauges also. And use a stick and a stop watch.
mtv wrote:My experience with carburetor temperature instruments has been mixed. I'm not sure I'd opt to install one. In fact, I just removed one from my current ride. There are too many variables to totally rely on one of these, frankly.
Just applying carburetor heat every once in a while, and any time you're at low power settings, and, of course for a moment just prior to takeoff has worked for me for many years.
8GCBC wrote:Might as well remove the fuel gauges also. And use a stick and a stop watch.
Aryana wrote:This frost/ice crystal detector works well. It doesn't rely on a temperature based warning to the pilot, but rather the actual formation of ice to begin to throw on the warning light.
You can mount the instrument far away from view but install the warning light front and center.
I've only had experience using one of these in a friend's O-470 powered 182. He seemed to be happy with it and I saw it work well on the foggy coast of N CA.
https://www.aircraftspruce.com/catalog/ ... etect2.php
I like these. I feel like these are more like a fuel totalizer and the temp guage is comparable to the not very reliable fuel guage. Ive not had great luck with the temp guage either.Aryana wrote:This frost/ice crystal detector works well. It doesn't rely on a temperature based warning to the pilot, but rather the actual formation of ice to begin to throw on the warning light.
mtv wrote:Aryana wrote:This frost/ice crystal detector works well. It doesn't rely on a temperature based warning to the pilot, but rather the actual formation of ice to begin to throw on the warning light.
That system makes a lot more sense than a simple thermometer.
That said, I can pull that carb heat knob a lot of times for $500 + ......
I just don't understand why some folks are so wrapped around the axle about carb ice.....it happens, worse in some places than others, but every carbureted engine has a very simple control to fix it.....
mtv wrote:Cessna did offer the carb temp gauge as an option in the O-470 aircraft they built (180/182) which are arguably the most prone to carb ice of any engine around, yet it was never required equipment.
Aryana wrote:mtv wrote:Cessna did offer the carb temp gauge as an option in the O-470 aircraft they built (180/182) which are arguably the most prone to carb ice of any engine around, yet it was never required equipment.
I'd argue the O-300 in the 170/172 is more prone to carb ice than the O-470 180/182
Mapleflt wrote:The 0-300 in my 170 makes carb is on a clear day, downhill with a tailwind. So to MTV's point the little black knob featuret prominently in my cockpit routine but I'm equally happy to garner further wisdon via technology on which to apply said Carb Heat
Aryana wrote:Mapleflt wrote:The 0-300 in my 170 makes carb is on a clear day, downhill with a tailwind. So to MTV's point the little black knob featuret prominently in my cockpit routine but I'm equally happy to garner further wisdon via technology on which to apply said Carb Heat
I've been flying behind ice makers built by Continental for a little more than 3 decades. I know the importance of and how to use carb heat.
I was simply addressing the claim that the O-470 was "arguably the most prone to carb ice of any engine around", which in my experience isn't true.
