RLHawk & I have experimented with camera mounts from the extreme (3#) to the very simple (3oz), and as usual, simple seems to be better. We are using the Drift Stealth cameras.
Our camera mounts are made of .125 thick 2024 Aluminum that we cut into a T shape and bent the vertical part of the T to 90 degrees. We have mounted the bracket on an inspection plate with two screws, utilizing existing fasteners and mounting plate. We did not use any vibration absorbing material between the bracket and inspection plate. We use a water hose bib washer between the camera and the bracket and it works extremely well keeping the camera stable during flight. The camera is mounted to the bracket via 1/4-20 allthread with hose bib washer between camera and mount, a flat washer, lock washer, wing nut and safety pin through the allthread. We avoid prop clutter by mounting farther out on the wing and adjusting the zoom level. We also have a wide range of camera movement to adjust the shoot angle.
We have run the gamut with getting audio from the cockpit onto the video without loud wind and engine sounds. Our solution to the audio has been to run a cable from the cockpit to the camera external mic jack. We then placed a small mic in one ear cup of our headsets. This works really well and catches all audio coming through the radios or intercom.
Feel free to PM either of us with questions.
Pics of the simple camera mount
Pics of camera attached
