So I got the plane back from annual, having done a lot of stuff:
* Lycon flow tested my carb, and like I saw from my engine monitor, saw about ~22 GPH at WOT. They changed the jet and also overhauled the carb. They saw about 25 GPH and I'm seeing 25+ GPH at WOT at about sea level DA (see the screen grab from today's flight)
* I found several induction leaks, but the major one was between the Y pipe and #1 cylinder, which was a gusher. Fixed that.
* compression tested OK, and borescope didn't show anything burned.
* the prop governor was set too low, now fixed to 2700 (Pponk 0-470-50)
So I test flew the plane today (cold day - DA ranged from -400 to 800 feet) after all of that, and grabbed the data. Based on the below screen grab from Savvy Aviation's web analyzer, I can make out a few things, but have a big question mark as well.
* I went from a GAMI spread of 2-3 to 1.1 (see the part of the graph where the Fuel flow slowly decreases, and note peak EGTs of each cylinder on the way down). That means the induction leak fixing did something notable and cylinders now reach peak EGT closer together - GOOD!
* I am seeing much higher Fuel flows on takeoff, and no longer have CHTs approaching 380 right on climbout - GOOD!
And the head-scratcher: Cylinder 5 EGTs are ~250 lower than the rest during full power/takeoff? Why?
Theories I think are wrong:
* intake leak - didn't find any there, and if the cylinder had one, it would run hotter. . .
* bad sensor - it falls right into line with the others most of the time, and is dead nuts with the others during various operations on the graph.
* stuck exhaust valve - the temp falls into line when leaned, and when carb heat goes on so I don't think so?
About the only things I can tell from the graph are:
* #5 gets hotter when I add carb heat (see minute 17 in the graph below) and falls into line with the others.
* #5 is my leanest cylinder from the GAMi sweep, and all the odds are leaner than the evens, with #6 being the richest (last to peak)
I used to have the crossover pipe insulated so maybe I had better add that back? I thought I checked the crossver pipe wasn't blocked bu?
Maybe this is an atomization issue? Maybe the cylinder is way way way too lean at full power?
I don't think this could be a sticky valve. .
ideas very welcome.
