It continues to be an amazingly warm December, and a perfect excuse to play hooky from work. After a couple of days of rain, the clouds broke and I jetted over to Sherman field for a quick visit with my friend Dick.
This is a good question. My thinking, which could get me in a lot of trouble, goes back to the TCDS. There is generally an equipment list spelled out as necessary for flight. For instance, some airplanes MAY not be flown without a spinner. It's part of the engine cooling system. But following that logic would one be allowed to fly without a seat for the pilot? I don't think so. There must be something deeper here knowing the fed's propensity for eliminating gray areas. One can certainly remove all the other seats. Wiser minds than mine should weigh in here.Vick wrote:I like these minimalist interiors - what's the approval basis for them? I heard of a guy who had stripped his interior and was later told his plane was unairworthy by the big brother types. Field approval to cover the removal of the factory interior and installation of just the insulation?
Jeredp wrote:
My plan was to talk with selkirk about buying the material in bulk from them. I've heard good things about them and would like to support a local northwest business. I've had the same experiance with Spruce. I wonder if selkirk would sell a guy the kit and an extra couple feet of bulk material to remake the ones that don't fit???
8GCBC wrote:I am one to remove everything that does't add to the mission. But, some interior finishing help cover control rigging, insulate and protect aluminum fuel lines, etc.
Noise in an SEL can be dampened considerably with a good finished interior.
55wagon wrote:I have mtv. I had an engine failure 2 yrs ago. Landed in a plowed field that was to soft (prior to bushwheels) and she ended up on her back. Did nothing wrong. Guy even said great job. Then gave me 3 warnings. 1.unsafe operation of aircraft in the air..wtf?? 2.flying in airworthy aircraft 3. Failure to quit flying it once I knew it was unairworthy. The reason... No interior panels or headliner!!! I argued it..which really worked. Ha. Then got my notice for a 407 reride to make sure I'm competent. Love those guys. Also categorized it as an accident not incident because the spar was bent. After I showed him it wasn't and was pleading for an incident, he took a pair of pliers, ripped my skin open more and claimed he could see 2 bent ribs and that means accident. I asked where it said that. He said, can't remember but ill check! Lol. Sorry for the rant. Just a sore spot.
aktahoe1 wrote:Could not help but notice the old hard brake lines.
AKT
bigrenna wrote:aktahoe1 wrote:Could not help but notice the old hard brake lines.
AKT
Actually those are brand new SS lines which were installed when the new Clevelands were installed along with the tires. They look old as they are wrapped in plastic loom for protection. I will replace the rest of the brake lines when I really get into the resto.
RE: up or under... Not sure what is correct. On my C170, they were below. On the Skywagon, they were above. We replaced the new lines the same way they came off. Seems to me they are much more protected above from shrubs etc than below.
Greg-
blackrock wrote:8GCBC wrote:I am one to remove everything that does't add to the mission. But, some interior finishing help cover control rigging, insulate and protect aluminum fuel lines, etc.
Zulu's are lighter.
robw56 wrote:
Greg, he is actually talking about the hard metal brake line that comes out of the fuselage and goes half way down the gear leg. You can't tell from his picture, but Kevin's steel braided brake line goes from the caliper all the way up to the fitting on the side of the fuselage. It's a pretty nice set up, I'd like to do the same thing on my plane.
bigrenna wrote:Ideas I love... Spending all this cash, getting to the puke point. (well is almost dry)
8GCBC wrote:blackrock wrote:8GCBC wrote:I am one to remove everything that does't add to the mission. But, some interior finishing help cover control rigging, insulate and protect aluminum fuel lines, etc.
Zulu's are lighter.
No?
What you flying where can't afford some common sense comfort?
