Matt,
You're 100 % right on the BAS stuff, and those harnesses could save your life. They saved mine, and I've been a big fan since.
Wow. Good one.ccurrie wrote:In my 55 170b I made covers for the rear ashtrays with the headset jacks in them then installed the ashtrays upside down so you don't kink the cords.
mtv wrote:Matt'
Couple things to consider:
When you move the battery from baggage to firewall (and I'd do sooner as opposed to later) also switch to the Odyssey battery....that alone will save you ten to twelve pounds, not counting the weight savings from wiring, box, etc. Atlee Dodge sells a battery mount for that.
Second, a friend has a pristine Cessna Airmaster that his Dad rebuilt. It had a leather interior. He put it on amphib floats, and weight was a big issue. He removed all that gorgeous leather and replaced it with some type of fake leather. He told me he saved forty pounds, and I honestly could not tell the difference. Do some checking..there's some cool stuff out there.
Third, get rid of that back seat and replace it with Atlee Dodge or BAS folding seats...MUCH more functional, and they CAN be lighter.
mountainmatt wrote:mtv wrote:Matt'
Yep, I plan on using the Altee Dodge STC and Odyssey battery. I haven't heard much bad from those running the Odyssey on a O-470.
Good to know on the fake leather (feather?), I will see what my options are when the time comes.
At this point, I don't see the Altee Dodge seats happening. My budget is just too tight for them at the moment. And honestly, I would rather spend the money on a Sportsman STOL kit if I had the chance. Don't get me wrong, I would love to have Atlee Dodge seats at some point, but it's low on my list of priorities. I know, I know....
Matt
robw56 wrote:Matt, I have come to the same realization, regarding bushwheels. Don't get me wrong I love my 26'' bushwheels and baby bush tailwheel, but they are overkill for most of the flying I do. 8.00s will get you in and out of 99% of most real airstrips. Bushwheels are only worth it when you are going off airport. When I get my plane back up and running I will have 2 weight and balances, one with the 8.00s and scott 3200, and the other with bushwheels. I may even get a second prop (cruise) to put on at the same time when the seaplane prop and bushwheels aren't needed. The difference will be about 30lbs of weight and maybe as much as 20mph, that extra speed will be nice when just flying around here at sea level. Good luck with your project, I'm looking forward to seeing what you do with it!
mountainmatt wrote:Thanks Greg for all the insight and experience.
After going back and re-reading this thread, I feel like I should do a quick Alaskan Bushwheel update for the 31x13x6 bushwheels on a Cessna 180. I have approx 50 hours on the tires and 100+ landings on all types of surfaces (less than 3% on a hard surface). This is my experience and opinion, YMMV.
If I had to only pick ONE tire for my purposes, a 31 would not be it. For me and my mission, off airport landings are fewer and far between and landing on improved and unimproved airports and airstrips are becoming the norm. The 31 is simply overkill and the speed penalties are very noticeable on a 180. At 22 sq, the speed loss is about 10-12 mph TAS, which hits the clock and wallet at the end of the day. This may be the difference between beating a weather front moving through, skipping a fuel stop, or landing at dusk with just enough daylight at my non lighted home field. A few other things, climb performance is slightly decreased, and my biggest annoyance while flying is the feeling the tires on the spring gear "dance" in the air with every bump. (This would be true for any heavy, large tire).
The good: The ground handling is not as bad as I expected (but I can see why many prefer the stiffer sidewall of a 29” bushwheel). It may seem like the sidewalls are soft, but at the controls it feels solid while taxiing and landing in crosswinds. I've tested them hard, and have yet to find a strong enough issue in this area to make me spend more money. The AOA has increased, but I can’t tell like I could on the Stinson. The prop clearance on the 31’s is unreal, even with the 88” seaplane prop. But what I like most about the bushwheels, they really diminish the abuse on the Cessna airframe. If I'm not planning a long cross country where the bushwheels are necessary, I will likely keep the 31's mounted (or until someone wants to swap me some good condition 29's. haha).
Overall, the best combo is having a tire for the specific mission. I thought I would never say this, but I'm really glad I kept the 8.00x6 tires, it's worth the hassle to swap them out for those long cross countries. I can see why the 8.50x10 tires on 10" rims are so popular on Skywagons, and why Wup recommends them for normal backcountry use.
That's my 0.02
