Jr.CubBuilder wrote:I just had the oportunity today to try out my propane pre-heater today for the first time. I had done some test runs outside the shop just to see if anything untoward happened, like a big fireball, but all went well.
I don't have any electricity on the ramp for my plane so the propane blower running off the car battery seemed like the way to go. It worked just fine. Tossed an old blanket over the cowl, wrapped the end around the spinner and stuffed the corners into the oil cooler duct. I probably gave it about 20 minutes of heat while I did my preflight, the temp. was in the high 20's F. That was enough to get the needle twitching on the oil temp by the time I was ready to depart. I think in the future I would do more like 30 minutes at that temp.
Let me just say that you gotta be REAL careful on pre-heats.
At 20F it ain't no big deal, but at 20, 30, or 40F below zero it is a big deal. You can blast heat into the cowl for a short period of time and get all the surface metal too hot to touch, and that oil temp will be, as you say, "twitching," but in reality all you have is hot metal 1/4 inch in from the surface, and a warmed up oil temp probe. Meanwhile your oil is sitting there in a big frozen lump, and it's not going to thaw out for another several HOURS worth of heat. Been more than one guy launch off at 30F below, only to come walking back to the ramp 30 seconds later with a seized engine.
Time is your friend with pre-heat, better is a Tannis or Tannis type heater plugged in over night with good engine covers. Or, like we used to do in the older days, drain the oil at night and bring it in with you when you go home at the end of the day's flying. Put the bucket on the heater for the night, and all ya gotta do is dump it in warm and you're set to go next morning.
And, don't forget your cabin. Want to eat a $600 gyro in just a few minutes??? Just spin it up at 40F below, and wonder why it fails on you on a whiteout day. Stick an electric heater under the dash while the engine's cooking, and drape a blanket over the glareshield to hold the heat in. Your gyros will thank you.
