caveat: I am not a rocket scientist, nor an aerodynamicist, sooo if you are and don't agree, maybe you can explain the flatter approach better.
But: Did you stay at a Holiday Inn Last night?
motoadve wrote:I was practicing with my instructor yesterday, and he made me come high and steep
Is this techinque the one you guys use?
motoadve wrote:He is stubborn and will not believe in anything said over the internet.
Skystrider wrote:"I have learn volumes."
Yeah. It shows.
Just ribbing you Zane!
Zane wrote:Skystrider wrote:"I have learn volumes."
Yeah. It shows.
I talk like a caveman. That's nothing new.
motoadve wrote:Whats the trick to loose alt but keep the same speed?I tried to pull the yoke and what happens is airspeed is reduced and alt maintained.
lesuther wrote:For nose heavy flare situations (particularly solo in a 182), I use full *down* trim on a short field approach with 100% success. You simply have to deal with *a lot* of wheel pressure that way in a 182. That little extra trim tab deflection is actually very significant, allowing a lot more flare, and keeps the nose wheel completely off the ground on roll out until the airspeed needle can no longer even register. In a 172, the pressures are lighter, and you can do a wheelie down to about a fast bike ride speed. You can grease virtually every light wind, maximum performance landing this way. With a passenger or two in the back, there is no need for this, of course, but when your mains touch, a few flicks of the trim wheel definitely help that nose wheel out. Try this at home first. Just remember to make sure you trim back to neutral before a takeoff...touch and go or otherwise.
Nosedragger wrote:I rarely fly at sea level and I don't have cuffs on my 182 but 55 would be getting too slow and mushy if the wind quit me.
GlassPilot wrote:Nosedragger wrote:I rarely fly at sea level and I don't have cuffs on my 182 but 55 would be getting too slow and mushy if the wind quit me.
Your Vref speed has nothing to do with altitude. The only concern when selecting what speed to fly is aircraft weight and flap configuration. I'm not sure if you were saying otherwise, but you mentioned sea level so I wasn't sure.
I've flown with guys who want to add speed when we land at high alt airports and I have to explain it to them also.
shortfielder wrote:I don't change my speed to meet my touchdown point. I adjust my glide slope with my throttle once I have my final approach speed established and plane trimmed as I want it, to maintain final approach speed. Really don't want to change it(stabilized) until I am ready to flare. Don't really want to go any faster, or much slower.
Guess there are lots of ways of doing it. But that's how I do my stabilized approach.
Gary
