GumpAir wrote:motoadve wrote:Whats the trick to loose alt but keep the same speed?I tried to pull the yoke and what happens is airspeed is reduced and alt maintained.
The "trick" is your trim wheel. The more you use it, the better you learn it, the more stable your approaches. If you're not trimmed properly, just a few ounces of more/less pressure on the yoke can make a huge difference in your airspeed. Then you're chasing needles, airspeed, and energy.
JimC wrote:Slightly off-topic.
Why is side slip and forward slip terminology in the UK reversed from that used in the US?
LittleGoat182 wrote: Other times though, that would end up with a premature landing. I.e. not a consistent response when I cut power...
Any input highly appreciated!
aktahoe1 wrote:Mountain Matt took this video this past weekend at the Caveman Ranch. You will see I hang on the prop through out the entire approach landing at around 35mph with a high AOA with full control and rolling to a stop at around 100'. I sure love my WingX / Sportsman / MT Prop. Its almost cub like. I could have very easily landed on my tail wheel first but that does not help you when you come down hard on the airframe.
Lots of folks on here talking about techniques. Anyone have some videos? I have watched this video about 50 times now and see something new every time. Thanks for sharing Matt!
http://www.youtube.com/watch?v=lN9Em2qX1Wo&feature=player_embedded
AKT
AKT
