mmartin1872 wrote:According to the reg's you as a manufacturer of a part can install said part in the aircraft, as long as it meets the requirements of the type certificate/design... The 180 I believe was certified under civil air regulation part 3. So you do some digging into car part 3, and there isn't much in there in terms of "the instrument panel" because it isn't primary structure. So, does changing the material that the instrument panel is actually made of, alter the type design? I can't answer that. I would venture to guess that it doesn't, but I also wouldn't bet my license on it..
So if you are wanting to change the instrument panel (as in the piece the instruments are actually mounted in) to carbon fibre, I think you'll need an Stc.
Now if you are just wanting an overlay (like I made to cover the instrument mounting screws, (mine is made of metal, newer cessnas are made of plastic)) that would be completely different because i would think that would be "cabin furnishings" which is listed as an elementary task in the reg's.
mmartin1872 wrote:Technically you can, but the issue is you are supposed to record the change in your log book. . What happens is transport canada,if they ever dig through your books, goes and says a weight and balance amendment wasnt done.. you as a pilot can't sign a weight and balance amendment. What usually happens is the interior just gets done and no one knows the wiser. Even better though, is when most mechanics change an interior, unless you ask, they won't do a weight and balance amendment either.
I also don't think transport canada would be digging through your books looking to catch you on an interior change unless you got yourself on their hit list.
A1Skinner wrote:Where are you located? That's is a great gesture. Nothing worse then not having a place to go or way to get places at an unfamiliar airport.
