Or something else? I've been doing some electrical system planning for my Bearhawk using the load planner on the Vertical Power website. One of the first choices is which alternator you plan to use: Internally or externally regulated. Is that the main difference between the B&C and the Plane Power? Looks like Plane Power offers Experimental kits which offers a choice of both types:
http://www.plane-power.com/products%20experimental.htm
The externally regulated B&C:
http://www.bandc.biz/belt-driven-alternators.aspx
Just curious if there is an opinion on this. The Plane Power appears to be a little less expensive.
Are all 540 variants belt drive?
And finally, for a modern, minimally equipped VFR aircraft with LED lighting, a single EFIS, single comm, and maybe some ADS-B goodies, what's a reasonable alternator capability? If you looked at the link above, my all-on load is about 40A. 60A? 70A? What's a practical buffer?
Thanks.
