An update on the Fravel SportHawk conversion, for the several people who I promised to keep informed via this thread:
I will have one of the first test-fit rough prototypes of the welded 4130 steel main landing gear fittings for show and tell at the Alaska trade show. The steel fittings are of course a little heavier than the damage-prone OEM aluminum extrusions, but they are five times stronger and will be a fraction of the cost of new Cessna parts. I will also have a CAD rendering of the new inboard and outboard fittings, so people can visualize the improvement in strength, longevity, and damage resistance. The new fittings have been designed to also allow the installation of the PPONK reinforcement (or not) as an option.
The parts kit is not yet certified, and so I will not be selling any parts at the trade show (still a few design details and finalizations in the works in the tail area). However I am confident enough that the redesigned landing gear system will pass certification to make an introductory offer up there involving the existing STC approval (which is approved and sell-able) linking it to the PMA parts kit when approved.
What I will be able and available to discuss in detail at the show is the tremendous improvements which are being made in streamlining and speeding up the conversion process. It has been finalized that (once PMA certified) the newly updated conversion will no longer require removing the wings, tail, struts, controls, rigging, etc. Thanks to hitting the "clever" button a few times, the conversion will be going from a "major surgery" project to something that can be done in a week or two.
Of particular importance will be the significant reduction of any disturbance of primary structure to do the conversion. The lower fuselage longeron hat sections and main door post structural skins will no longer be disturbed. Floorboard sections will remain attached. The control "tunnel" will not be removed or de-riveted. In short, there will be no risks related to "relaxing" or "un-jigging" the primary fuselage-to-wing structure.
The PMA parts kit will feature lightweight aluminum main gear, with options for the gun-drilled brake lines and drag-reduction profile shaping, doomsday strong 4130 main gear box fittings, increased cross sectional area bulkhead structural caps. A drilling jig and a carefully designed procedure will guarantee no gear box mis-alignment and no damage to mounting holes. There will likely be options for tailwheel units, axles, wheels and brakes.
Long story short, those pilots who have been waiting for something that fits between the Super Cub and the 180, and want a large cabin bush plane that addresses today's fuel and maintenance costs... will probably want to come by the EZ Flap booth and see what I've been up to
