Backcountry Pilot • Belly Pod
Belly Pod
18 postsPage 1 of 1
Belly Pod
Has anyone in the BCP community witnessed or been party too a Belly Pod being installed on a 170B ?
Mapleflt
Re: Belly Pod
Reach out to Aeropod...
jaudette offline
Aircraft: Husky A-1B
Vans RV-7a
Re: Belly Pod
Any chance you have their web address, I Googled the name but no luck !!!!
Re: Belly Pod
Mapleflt wrote:Any chance you have their web address, I Googled the name but no luck !!!!
Ooops! Should have been more clear. His username on this site is aeropod.
jaudette offline
Vans RV-7a
Re: Belly Pod
Ah, got it tks
Re: Belly Pod
Unless the belly pod comes with a gross weight increase, I think it's addition would only reduce the amount of stuff you can carry (useful load).
Bagarre offline
Re: Belly Pod
Tony (Aeropod's) pod would have to be FA'd for a 170, and due to the lack of power would be hard to do. Hasnt been done yet for a 180... Its just approved for a 185.
www.avthreads.com
Re: Belly Pod
All good considerations thanks, time for Plan B
Re: Belly Pod
Install an extended baggage if you haven’t already. It adds quite a bit of extra space.
Re: Belly Pod
Curious as to what your "plan B" is?
Your question is a good one. An extended baggage kit is great, however it places extra weight further aft of CG which isn't ideal. A cargo pod is a great way to carry bulky items, and places the weight in an ideal location. Obviously, either way you would need to be mindful of your weight and balance.
Aerocet was seeking certification for a pod for 172's. I spoke to them a few months ago and they said they were "almost there". You might want to talk to them.
On The Fly offline
Aircraft: C`182K
Re: Belly Pod
On The Fly wrote:Curious as to what your "plan B" is?
Aerocet's pod has been in the works for a long time--I think it was at OSH 3 or 4 years ago. It sure looked nice, and I could see it as a possibility on my P172D, if it didn't add much drag. I'm always running out of room for light but bulky items, things like the cowl and prop covers in the winter. But at the rate it's going, I'll be grounded by old age before Aeropod is ready to sell them.
Re: Belly Pod
I think Bagarre mades a good point, the weight of the pod itself in the lower gross weight aircraft is limiting. An extended baggage area therefore makes more sense for this class of airplane, maybe not so much of an issue from 180/185 and up.
Mapleflt
Re: Belly Pod
What's a pod weigh? 50 pounds? More, less?
I'm thinking these are fiberglas?
Maybe a good item to be done up in carbon fiber instead.
Re: Belly Pod
If the pod weighs 50 pounds, that's 50 pounds less you can't carry.
particular in a 170 where you run out of useful load long before you run out of room in the cabin.
Bagarre offline
Re: Belly Pod
Cary wrote:Aerocet's pod has been in the works for a long time--I think it was at OSH 3 or 4 years ago. It sure looked nice, and I could see it as a possibility on my P172D, if it didn't add much drag. I'm always running out of room for light but bulky items, things like the cowl and prop covers in the winter. But at the rate it's going, I'll be grounded by old age before Aeropod is ready to sell them.
Don't lump me in with Aerocet!
I can't see much utility at all coming from a pod on a 170 or 172, or even an old 180. It's already WAY too easy to get those airplanes over gross in stock form, no need to add room. I owned a really cool 170 that was way too easy to get over gross. It would haul it no problem, but I'm sure it would have lead to problems with the feds if I had bent any metal.
AEROPOD offline
Re: Belly Pod
Whoops! Fat fingered that one, didn't I?
Re: Belly Pod
Bagarre wrote:If the pod weighs 50 pounds, that's 50 pounds less you can't carry. Particular in a 170 where you run out of useful load long before you run out of room in the cabin.
I agree. Just curious what a pod weighs.
Re: Belly Pod
Full size pod like a Piat Pod, with no ceiling, which would fit a 172, older 182, 180, or 185 weighs 35 lbs.
On The Fly offline
Aircraft: C`182K
18 postsPage 1 of 1
