Rob wrote:poking your nose in a drainage for a look see?
1) Don't do it at tree top level...
2) Slow it down some...
3) Don't like what you see? slow it down more and roll it around while letting it have it's head. Yes you'll be descending, but you were going uphill, now you’ll be going downhill and you're gaining energy enough to come back in with power and climb on the way home (down stream).
Want to add flaps to the mix? Go for it, I do, but use them as needed to keep it trimmed, not as a tool to try and remove the wings.
PapernScissors wrote:I've noticed from the NTSB and FS accident reports that it's not always 'bad decisions' that crumple aircraft and kill people. Nor does Alaska have a lock on box canyon crashes. In the lower 48 several states in the NE, NW, central mountain states, and SW have a history of pilots who mistook (box)canyon X for the gateway to a pass.
I think this discussion is great. Lotsa takeaways!
So far the problem of a consequential wrong turn seems to be overlooked. For me, besides flying in canyons with a little spare altitude , S.A. has to include a good 'google earth recon' of any in-canyon route I might fly. In addition, like many pilots, my cockpit has a moving map (i.e. Foreflight) to keep me honest and continuously oriented. The canyons look really different at 2000', 1000', and 500’. Personally, 1000’ is my floor unless I'm landing, departing, or have to descend to get a closer look at something worth the risk.
Thanks for that detailed response. It is very interesting to think about. I was always taught to add throttle in the turns to maintain speed. Now that I think of it, I was always taught to maintain speed in the turns at all times. The problem in the video or in a similar situation to the video is that you are already at full throttle. If he was already at Vx, also, there is no way for him to climb above his horizon, and the only way he can maintain his airspeed is to lower the nose. I really appreciate this discussion as it helps me to think through all these things. Hopefully I'll never need them.contactflying wrote:Allowing the nose to go down as designed for safety increases the airspeed preventing the stall. Yes, the airplane wants to return to the trimmed airspeed. The problem, in steeper than 45 degree turns is that the nose goes well down because the airplane wants to return to trimmed airspeed quickly. Once the nose is below the horizon, we can move the stick back a bit to prevent this extreme tuck. Move the stick back, not pull a lot of pressure. Feel the g load. If we have cruise airspeed before the turn, we can pitch up to zoom up to slow down to increase the rate of turn. The slower we turn the faster we turn because the radius is so much less. Also turning into a crosswind helps. But, we have to release this back pressure in the turn. We have to allow the nose to drop below the horizon. Very uncomfortable at first, but very safe. Once we have banked greater than 45 degrees, the rudder is helping push the nose down. This is good, but no we don't want to diver at a very steep angle toward the ground for a long time. Of course, when the airplane automatically drops the nose and automatically returns to cruise airspeed with the nose down, it will now automatically pitch up to stay at cruise airspeed.
In a situation like this, we just don't have that much vertical space available. No problem with zooming up wings level to near stall, banking at whatever bank is necessary to miss the ridge across the valley (hopefully upwind), and allowing the nose to drop automatically. If we have banked to 60 degrees, say, after slowing to near stall, the nose is going to go way, way down. Once the nose is below the horizon, we can safely take some of the tuck, the way down pitch, out. The stick force will not be high taking part of this tuck, this pitch down, out. Because we are initially slow, it will be light. The trick is to take that extra tuck out before we accelerate so much that the stick force is strong to bring the nose back up. And we want the wing to again be level when we pull out of the dive to prevent graveyard spiral.
This airplane in the video had used up all extra airspeed. He had no zoom reserve. He really needed to start the zoom up with cruise airspeed and start the turn with vertical space available to allow the nose to go down naturally into and he needed to get on the rudder a lot (with the nose below the horizon) to get the turn done quickly. Use as much zoom reserve as is available, bank as much as necessary, allow the nose to go down naturally once the rudder is led and the bank initiated, if steep bank was necessary take some nose tuck out after the nose is well below the horizon, level the wing before pull up out of the dive.
Sounds like a lot, but is all very natural. Same as the lazy eight except happens quicker. Very smooth, all 1 g except pull up wings level from cruise to start and wings level followed by pull up to finish flying over the target. Target is the lowest part of the valley going down drainage.
Quis wrote:I know that there were a lot of other things that should have been done to avoid the bad situation and that any answer is complete speculation, but in that famous videoed 1984 L19 crash near Tabernash, do you think that if the pilot had let the nose sink in his turn instead of pulling back, could he have completed the turn safely?
