jrc111 wrote:The relevant Service Manual 1953-1962 (Figure 6-8) describes only centering the bellcrank, not pinning or other means of securing that position, or the value of doing so. I'm open to finding out real-world ways of accomplishing replacing the cables and re-rigging that might not be detailed in the service manual.
The common parctice among mechanics is to pin the bellcrank, or as mentionted above, make bolts to place in the slot to 'pin' it in the neutral postion. This ensures that the proper travel in each direction and also inhibits movement and slop while tensioning the cables. If the bellcrank does not stay centered in the slot during the rigging process, it easy to rig the system with yoke neutral and the ailerons not. The result is the limited travel in one direction and over travel in the other direction. Like I said, later model Cessna's incorporated the hole to physically insert the pin in order to accomplish this.
The main objectives are to keep the yokes and bellcranks neutral throughout the rigging process, bring the cables to the proper tension, then adjust the rod ends as necessary. Can't go wrong with the service maual!
One last thing I will mention is that I have seen people try to correct a heavy wing by adjusting the rod end at the aileron. That is wrong! The rod end is used to fair the aileron trailing edge with the flap trailing edge. A wing heavy condition is corected by adjusting the eccentric bushing at the wing attach points. Good luck!
