Hello All,
Its been a long while since I have visited this forum as I was busy with a very demanding job. I have since quit and become self employed and now work out of an airplane hangar at KWHP. A much needed upgrade in lifestyle. Also recently adopted a baby. So with the baby, my desire to build a 2 place tailwheel has shifted to more of a family camping plane/traveling plane. I have made the tough decision to make the family plane a nose gear to avoid the chance of a groundloop with the wife and baby. I know if it ever were to happen I'd be flying alone thereafter. I can always partner on a 2 place tailwheel with a friend. So this led me to looking at a C182 and I have a few candidates with many questions. Would add an airglass fork and larger tires all around. nothing too big likely 850s
Plane #1 Price 49K
58 C182a, just under 5k hours but engine about 350SMOH. Owner bought it on a whim as a project to get it back to annual as it sat 13 years. Owner is an A&P and said the engine was pickled properly. He was not looking to sell but responded to a post I made online looking for a C182. Its not ready to sell, but small things remain like Pitotstatic test and to set up the Garmin adsb than it will be good to go. He has flow it about 2-3 hours recently as shake down flights. I have a friend with a 61 182 helping me with advice and he has a few concerns with the pickle. First no way to ensure it was properly pickled. Just taking a guy at his word. Also he said pickled engines that sat a long while run fine for an initial period, but will develop leaks over time from dried out seals. This is my main concern. Is this common? Only other issue with this plane is the radio is down low under the pilots yoke and the instruments are spread out across the panel and no 6 pack should I ever want to get my IFR. at the moment that is not really something I want to do. Owner has been forthcoming with the pros and cons of the airplane. Over the time of getting it back to anual the only corrosion he found was in the cabin ceiling behind the headliner. He says its only surface and mild and Spar cary though is clear. No Cowl flaps and its hot as balls at KWHP most of the itme.
Plane #2 Price 52K
Is a very nice 60 with 3 bladed hartzel prop and nice center stack radios. Only panel issue is no audio panel just switches. Engine is run out around 1715 smoh. Prop is 1k SPOH. Plane TT is 3975. From what I can see plane is very clean inside and out. Just run out. O-470L overhaul would be 35 to 40K I imagine bringing the cost to high 80s unless i get the purchase price down. What would a PPonk run? I have the funds to do the overhaul, but unsure if I want to put that much money into a 61 C182. Friend with 61 is pushing me away from a straight tail to a 60 or 61 as it has te extra windows, cowl flaps and rear bulkhead change gives more room for tall passengers which is a good thing. I am 6'4, wife 6'1 and dad 6'3"
Plane #3 Price 59K
another nice 60 but not quite as nice. Panel is useable but needs some updating. Airframe looks clean but inside has a mishmash of cloth and leather seats. The good is engine is mid 300's smoh. Just received logs and need to look into damage history. i believe it did have gearbox damage in early 60s.
Plane #4 Price unsure
C182P that may come up for sale at my local airport. Was not looking for a wide body and wanted manual flaps, but both myself and wife are tall. parents too and also we are heavy. If its a fmaily plane and I still partner on a TW airplane than a widebody C182 may still do 80% of what I want. P model has a huge useful load.
I know its tough to really answer which to buy, but more want advice on above scenarios.
Plane #1 Get the straight tail I prefer and forgo cowl flaps and take a gamble on that pickled engine. Also deal with the radios in an odd place for access. Not too worried about the lack of a 6 pack.
Plane #2 Nicest of all 4. 3 bladed prop gets me a bit more ground clearance when off airport at expense of a bit of cruise. I like the clearance. Buy it for the clean airframe and bite the bullet and do an overhaul. While its expensive, I end up with an engine I know over a gamble. I am still waiting to hear if it was ever topped which may buy me a bit more time. Would a really nice 60 with a zero time engine be worth 90K. Panel would still need some updating, but id be fine to leave it as is for a while.
Plane #3 Pretty nice, but inside is a bit of a mess. Yet 59K and no overhaul leaves some cash to clean up the insides and still have money left over in relation to plane #2
Plane #4
Need to decide if I want to give up the Johnson bar flaps and lighter control for more speed, more useflul load and ore roomy.
Sorry for the long winded post, but in a bit of a pickle on decisions.
Take care and good to return to BCP.
Marc
