There's little doubt that battery technology has improved greatly over the past few years. I suppose part of it has been triggered by the desire to miniaturize cell phones and then tablets, and add more usable time to both of those, as well as laptops. Lithium batteries (once controlled properly) have proven to be a real game changer in lots of ways.
A couple of years ago, I bought a PleasureWay Ascent van camper, with a 200 Ah lithium battery pack (2 100 Ah batteries in parallel). The size of the combined batteries is about the same as an 8D wet cell battery, and although they're heavy, they're nothing like the 8D's weight, which is enormous. 200 Ah lithiums have more actual capacity than a 285 Ah 8D wet cell, because the discharge rate of lithiums is fairly flat down to about 20% left, when it drops off precipitously, whereas a wet cell or AGM battery's discharge rate is relatively linear, and it's pretty much dead at 50% discharged. As important, lithiums will bounce back from being deeply discharged below 20%, whereas both wet cell and AGMs can be ruined if discharged below 50%.
I compare those because my old RV had an 8D in it. I got pretty accustomed to its usability, which essentially was a short weekend of two nights and about 1 1/2 days without starting the engine or generator, being pretty careful about electrical usage, shutting off lights, minimizing TV watching, etc. My Ascent is good for about 3 days and nights, and I don't have to be nearly as careful about usage--I can basically live like I do at home if the sun is out during the day (solar trickle charging helps some), and if not, then I need to recharge before that 3rd night.
But if my batteries die at their 80% usage level, it's no biggy. If an electric car's batteries go flat, it can pull over to the side of the road. If an airplane's batteries suddenly die, it's like running out of gas, and that may mean a tricky landing--not the recommended way to end a flight. So to be repetitive, I wish Harbor Air well, but I think they're really going to be in the proof of concept stage for awhile yet.
