Don't remember ever trying it on an airplane.
"Won't work on aircraft spark plug harnesses as they are covered in faraday shields and would obscure any arcs. But it is a good diagnostic tool for any other spark plug leads.
wannabe wrote:Newvizor
Don't waste your time looking for an AVCON motor mount: At least not from the alleged AVCON Co. Lots of other postings about them. Some almost humorous. May re-write some of it on request .
Best bet (last I checked) is still DELAIR in Porterville Ca. Young fellow name of Chris took over the business after Harry Delicker died. Chris had worked for Harry for years and has done some of the best "show" quality work I have ever seen. They also have larger fuel tank kits. I installed the larger of two options in my 170-B. I also put in their "forward" mounted muffler system.
They (Delair) have a full STC with kits and materials for 0-360 conversions.
Wannabe a different Chris C
Battson wrote:Are those all Champion massive electrode plugs?
Do they all have the same P/N? Looks like maybe some may not have internal resistors, while others do, which could be messing with your ignition. Otherwise, you have some bad plugs there (cracked internal insulation, maybe, could be shorting out at high power settings).
I am just guessing at the cause, this is internet advice. It sounds like either an ignition or an air/fuel ratio problem.
Zzz wrote:Another wild possibility: didn't the 3SPA have a Venturi AD that caused some vibration? Perhaps some flutter or cavitation effect at higher flow rates?
Haha that's kinda out there. Carbs and induction can be mysterious though in how they manifest.
contactflying wrote:Newbizor,
You may have the C-175, 7635M. I only got from 300 to 450 SMOH on the GO-300 when a rod bering turned, quit oiling, and beat the engine to death. I landed in the desert, had it rebuilt, and traded it in Lubbock, Texas for a Pawnee.
The gearbox had some play. That big long prop made it rattle a lot in strong, gusty afternoon winds.
contact
lesuther wrote:High RPM stumble can be caused by running past lean on fuel flow as mentioned, and can waver like your video. Running rich generally means bogging down, but I have not seen it manifest with surging. After verifying external spark timing, I'd check carb float operation (easy), then evaluate mixture. If small mixture changes from full rich have an effect right away on how bad it runs, then voila...fuel issue. You might check primer line leaks as well. I was pretty surprised how much one of those tiny tubes can affect performance when it is leaking pretty well. I don't think it would really explain the problem you are seeing though. If primer use during WOT affects things wildly either better or worse, it is another clue.
The dwell is often an overlooked but common problem for high RPM operation though. In a car, point gaps that are too large or too small don't allow a decent spark at higher RPM for different reasons, and it can definitely cause surging. I think the same issue could exist for mags. The procedures for planes are straightforward for both Bendix and Slicks, although I am only familiar with Bendix to check the gap and dwell and opening location. If the mags were worked on, it is conceivable that they both could have been set improperly at the same time. The condensers (caps) are easy to replace and cheap, and so are points if they look pitted or the cam bumper is worn.
The good news is that these are all pretty fast to check- an hour or two if you have a friend to lead you along.
Good luck.
If you want the O/H manual, let me know.Newbizor wrote: I'm still trying to figure out exactly what the air metering pin/mechanical economizer do exactly and if they might be affecting the air/fuel mixture at full throttle.
lesuther wrote:If you want the O/H manual, let me know.Newbizor wrote: I'm still trying to figure out exactly what the air metering pin/mechanical economizer do exactly and if they might be affecting the air/fuel mixture at full throttle.
fast eddie wrote:Check your fuel flow. Could be in the hose that feeds carb. Might be an internal flap inside the hose. it happened to me took lots dollars to find.
Bdiazair wrote:Maybe a quick way to determine if it's running too lean at high rpm would be to pull the carb hear and see what it does. This is also a good way to check if you've leaned too much while in the air.
PAMR MX wrote:I would bet ya a beer both magneto condensers are bad.
DeltaRomeo wrote:The harnesses do go bad in spite of a solid conductor. I suspect mine are due for replacement (1200+ hrs)
onefitty wrote:PAMR MX wrote:I would bet ya a beer both magneto condensers are bad.
Yup, my money's on condensers and / or points
Newbizor wrote: I really hesitate to do that because they were just done.....
NimpoCub wrote:Newbizor wrote:When something goes wrong, check the last thing you changed.
Newbizor wrote:Bdiazair wrote:Maybe a quick way to determine if it's running too lean at high rpm would be to pull the carb hear and see what it does. This is also a good way to check if you've leaned too much while in the air.
I did try that and I get a 200ish rpm drop at full power.
