Frankenflaps wrote:
I would appreciate some opinions on whether to fly with a seemingly slight? fuel leak from my left wing sump drain. The plane is a Cessna 182P. The drain stem was removed to drain fuel when the fuel selector valve required repair a month ago. It seems the leak could be the seal. The tanks are nearly full and I had planned to fly out to the backcountry for a day. I would like to fly, use up the fuel and then tend to the leak. I have included a photo. There is not enough of a leak to collect on the ground. It seems to just stain the areas shown. There is no fuel smell inside the cockpit. Do you think it is safe or advisable to fly for a day, deplete the fuel and then effect repair? Thank you.
You only need to empty the tank that you need to change the gasket on, just don't put the selector on both and it won't crossfeed. Then the headliner has to get opened a bit so you can pull the sender out and change the gaskets.dez180 wrote:How difficult is it to change the sender gasket ,I guess both tanks must empty ,
