I had problems with a couple Gill batteries in a row a while back. The voltage at the terminals would dip down to around 9 volts (from a 12.1 volt static voltage) while cranking, despite being brand new. I got frustrated with slow and unsuccessful starts, and really tired of hand propping. I got an Odyssey battery to try.
The load line of the battery was incredible, and the prop swung giddily fast. The starting issue seemed almost worse, however, and the Odyssey simply does not have the stored energy of the conventional batteries and started losing steam after just 30 seconds of cumulative cranking- much faster than the conventional battery. I also saw the first kickback I have ever seen...and somehow did not break anything. I have an old adapter and starter. The voltage during cranking never got below 11.7 volts until it would begin to die fast.
I got rid of the Odyssey and got a Concorde. The voltage never gets below 10.5v on a cold startup, and the engine generally starts on a few blades.
The only explanation I have for the train of events was that the Odyssey battery swung the prop fast enough to decouple the impulse coupling of at least one mag (Im not even certain if both mags have the coupling, and it isn't mentioned in my manual). I believe that is why I witnessed a kickback. The kickback actually seemed to happen before I had released the key.
