I had a new style adapter. Indeed the spring broke in the center. Ordered a new style adapter and put the old TCM energizer back on. Hard to pinpoint the insult exactly... We just installed rebuilt mags at annual, so it could have been a slipped/missed timing issue, the skytec, or just age. Adapter had 1100 hrs on it.
If you dont know what folks are talking about RE: the spring, you can see it wrapped on the gear shaft in the pic above. The one on the right has the broken spring. You can see that it has migrated toward the camera a bit. The break is a bit deeper inside the housing.
The root of the issue here is with the MT prop. If you choose to run the MT on the Cont, I would say it's probably safe to assume you should expect to break an adapter at some point. Of course this may never happen and for sure some will cry BS, but IMHO a non-biased owner would be wise to expect it. There is just not enough mass to carry the prop thru the compression stroke if there is a kick back. If you ask Cont, they will tell you the same and recommend not using the prop. Of course MT US and Germany will say its fine, but as more and more issues present themselves it is getting harder to avoid the evidence. There is a big battle brewing now between Cont, Cirrus, Skytec, and MT with each pointing the finger at the other. Time will tell...
At any rate, the new style adapter was installed ($1k ouch) which coincidentally was also the strong advice of Ron from Niagra Air Parts. When asked his best advice to avoid this issue in the future, he surprisingly advised to take the MT prop off and put it on the shelf, at least until he got approval for his faster turning starter which is in the approval process. While not ready to do that quite yet, he has a persuasive argument. Ron also recommended running ElectroAir electronic ign as this would provide a more precise timing. (don't know if my pocket book is ready for this...)
Sometimes to get the adapter out, you have to pull the motor, or at least pull the mounts and tip the engine. I was lucky and we were able to just slip the adapter out with just a cut knuckle or two. All in all, the swap was no biggie. (just a kick in the pocketbook)
RE: Running an old adapter: Yes the old style adapter can survive a kickback a bit better than the new, however is not advised to run the old style starter adapter due to catastrophic engine failure in some circumstances. There is even a a Cont SB out for some 520's and 550's. (MSB11-4B)
Lots of "internet" info for an individual to wade thru. Fact is that the stock stuff works pretty well. Once you start modifying, you should expect that some systems will start to get out of balance, and when that happens, stuff breaks and you spend more $$$. You pays your monies you pays your chances...
