One knife I keep coming back to again and again is my EnZo Trapper in O1 carbon steel. It's a favorite knife when I want something a little stouter than my slim puukko's but don't need the all-weather capability of the Fallkniven F1. Generally when the weather gets colder and I know I'm going to have to make more fires I cary a bit stouter knife, and the Trapper fits the bill. When it gets colder still I ad an axe.
I bought the knife blade and put on my own handle. The mahogany wood came from a slab my aunt brought home from SE Asia forty years ago. The wood is light and water resistant and makes the knife easy to cary. Since there was no sheath I made one out of kydex. I started making things out of kydex under the mistaken belief that it was easy to work with...it's not. At least not if you want something that looks good. I'm a total hack but it does the job. One day soon I'll start making ugly sheaths out of leather.
EnZo makes this knife in a lot of different steels, including O1, D2, and N690Co stainless steel, in both a flat and scandi grind. I chose O1 with a scandi grind because it's easy to sharpen and cuts wood superbly.
I've got nothing good to say about D2 steel in a knife other than it will hold a terrible edge forever, but the N690Co is a surprisingly good stainless steel. I can recommend it for someone who doesn't want the maintenance of carbon steel. Scandi ground knives cut wood the best, but flat ground blades are better for food preparation and similar chores.
Putting a handle on a Trapper is pretty easy and quite rewarding, especially if you have some wood you're fond of. In general it's a lot easier than putting a handle on a stick-tang knife.
I quite like the knife, but wish the blade was about an inch longer. They do make the same blade an inch longer, but it's hard to find. The short model comes up just a bit shy every now and again.
It's stout enough to batton but still has an excellent point and the blade is narrow enough for precision work. It carves wood very well, which is 99% of what I do with a knife, though I have cleaned a few fish with it, too.
I like using this knife more than the Fallkniven F1...it's a warmer in the hand and carves with greater precision, though it lacks some of the F1's utility and do-it-all capability. Prices are all over the place...as low as $65 for a blade in inexpensive steel to $150 for a finished knife with high-end handle material. You won't find EnZo knives at the Walmart-In-Camo places, but you can find them online. Thompsonknives.com is a reputable guy and I've bought lots of knife blades from him...straight shooter and very decent prices.
