Hammer wrote:hotrod180 wrote:Halestorm wrote:You saw no effect? You should see a slight rise (25-50 rpm) before engine shutdown. This is the test to see if your idle mixture is set properly....
yes, this happened at idle cutoff just before the engine quit. No effect before that, which leads me to believe that the mixture knob position doesn't mean much on the ground.
I'm not very familiar with your model engine, but every engine I've flown behind could be leaned effectively on the ground. It's often a delicate procedure, balancing between rpm-rise and engine shut-off, but it should work. What I've read on the subject says there is zero risk to the engine with aggressive leaning for taxi...just lean aggressively enough that you cannot accidentally take off without readjusting the mixture. After start-up I lean to where I can't even taxi forward without adjusting the mixture until the engine is warm.
It's not just fouled plugs...lead build up on your valves can cause them to burn. If the valve doesn't seat properly (because of a bit of lead buildup around the edges) it cannot dissipate heat. Running too rich can be more damaging to your valves than running too lean, though I don't know how much ground idling affects that.
Hammer nailed it.
A few years ago there was a discussion of this on another forum. I've never been a big advocate of leaning for taxi, so I contacted a tech rep from the outfit who makes our carburetors....which at the time was Superior, I think. The engineer came back with a response that, yes, leaning during ground ops MAY help to prevent lead buildup, but the mixture has to be taken right to the edge of idle cutoff for it to have any effect. His point was that if set like this, ANY increase in power, even just a bit more rpm to turn during taxi, should cause the engine to shut down on cutoff. His point was that, unless it's that close to idle cutoff, it basically does nothing.
The policy at the school where I worked was to lean for taxi. I can't tell you how many times, however, that I caught students pushing up power for takeoff without first going to full rich mixture. This to me seems to be the only risk to leaning for ground ops. Discipline is key there.
But, as Hammer notes, to achieve any benefit from leaning on the ground, you really need to lean aggressively.
I don't lean for ground ops. I ran an O-360 that fouled plugs regularly, so tried leaning for ground ops, and over the course of a few hundred hours, it made absolutely no difference. And, yes, that carburetor was properly set up.
YMMV
