Nice! Looks like there is two people in there, probably wasn't me that day, must have been a marketing flight or a customer receiving training. My flights are usually solo, return to service or phase 1 required crew only
pburns wrote:Figured I would resurrect this. There has been a fair amount of activity here the last month or so. This C-130 is from the 109th air wing out of Scotia ( near Albany). They have a signature red stripe on the tail. These guys get outfitted with skis and travel to Greenland and Antarctica fairly often. This shot was a week or so ago. About as close as I want to get. He actually dropped down a little lower after I took this. I think they have a pretty good time.
Pete
fredy wrote:Several previous comments about the widths of training routes. Lots are 5 miles either side of the centerline, but I’ve also been on some that are up to 20 miles either side of the route, so width can vary a lot. The AP-1B is the source document that describes all MTRs by defining points, widths of the legs, and altitude, should you have some nearby that you want to know the specifics of what’s allowed.
https://www.daip.jcs.mil/pdf/ap1b.pdf
BigBen wrote:I fly in an MOA just like I fly everywhere else VFR, they aren’t restricted. If the military is using it they can watch for me via ADSB or out their window, just like I’ll be watching for them.
stretch wrote:Interestingly sounds like if the fighters radar is active and you are squawking they will see you? Maybe.
EvilEagle wrote:BigBen wrote:I fly in an MOA just like I fly everywhere else VFR, they aren’t restricted. If the military is using it they can watch for me via ADSB or out their window, just like I’ll be watching for them.
Fast movers don't have ADSB in or out so they can't watch for you via ADSB.stretch wrote:Interestingly sounds like if the fighters radar is active and you are squawking they will see you? Maybe.
Only if they are looking for the 1200 code AND the radar isn't being used for another reason (likely using it for training; looking for something besides 1200). Of course, fighters can get a lock on bare metal but a slow mover may be in the radar notch/clutter and a mostly fabric or fiberglass airplane may not give enough of a return to show up on radar unless they are specifically looking for that type of threat (then they wouldn't be doing their primary training mission).
BL: Radar isn't a perfect system and fighters don't have ADSB; don't assume the jet has global SA.
NineThreeKilo wrote:EvilEagle wrote:BigBen wrote:I fly in an MOA just like I fly everywhere else VFR, they aren’t restricted. If the military is using it they can watch for me via ADSB or out their window, just like I’ll be watching for them.
Wonder if them not running ADSB is going to change after the DC crash
mtv wrote:NineThreeKilo wrote: Wonder if them not running ADSB is going to change after the DC crash
Probably not.....the helicopter involved was ADS-B equipped, but it was apparently turned off.
StillLearning wrote:A couple of years ago I was flying east toward the Lake Andes MOA west of Sioux Falls. I was on flight following at 9.5, I was told I either had to go around the MOA or under it. Under I would have no flight following, if I went around I could continue flight following. I went under the MOA, I kept listening on the same frequency for center, I heard them clear someone ( I forget the call sign) for 500 agl to FL 300 their discretion.
I can see why they didn't want me in there, but last I looked flying through was still legal.
hotrod180 wrote:I guess the government can get away with things that you or I can't....
slowmover wrote:hotrod180 wrote:I guess the government can get away with things that you or I can't....
We have a large and active C-130 base in Arkansas, and deconfliction with the C-130s doing sub-250 knots at low altitudes outside of special use airspace is a concern. They also turn their ADS-B Out off, which makes it harder for me to see them.
As a retired C-130 dude I still know a few people so I asked. The problem is that military ADS-B data can be analyzed by our adversaries to determine the tactics our forces are using. This might sounds like a minor detail but it can become a huge weakness that could be used against us in combat.
I definitely think there are times and places where it military aircraft should have ABS-B Out operating, but I also concede that there are times and places where they have a legitimate need to turn it off. Some of those places are going to be outside of special use airspace.
