Good call on removing the fin strobe. We did it a few years ago and gained about 3 mph. The replacement lighting is very bright(Whelen 650 and 500)
You'll love your Pponk engine.
colopilot wrote:I'm in a bit of a slow phase here while I amass parts and paperwork, however one big step is finally moving. My P-Ponk in a box is crated up and ready to ship! The LTL driver will pick it up in Wasilla tomorrow, and then begins a journey across ocean and land to my hangar late next week. My O-470 wasn't a good candidate for anything other than a reman, so I'm dropping in an IO-520-F instead.
This is turning into the airplane BCP built. The engine, prop (through Flight Resources), STOL kit, nose fork, and transponder so far have been found or supplied by people on here. Pretty cool!
I was also slightly stressing about finding an LED tail beacon that would fit the available replacement fin caps (along with a new cap, mine is cracked) until I realized the 1957 182A was type certificated mere months ahead of the mandate for such things. FAA says anything with a TC before 4/1/57 has no requirement, and Cessna conveniently TC'd this plane on Dec 7, 1956.
Given the amount of other LED lighting to be installed, it will look like a UFO and still be significantly better than the single tail strobe it has now. So, the vertical fin strobe beacon comes off and a flush fin cap will go on. This should shave a few pounds off the tail (this may not actually be good for CG), get one more draggy thing out of the air (always good), and clean up the electrics a little bit.
jaudette wrote:If you need help when that thing gets here, shoot me a text!
Speaking of beacons, If you haven't purchased a vertical top yet, Stene sells a vertical top for a small beacon for your airplane (assuming that it is a 182A) that will fit the Aeroled Sunbeacon II just perfectly. We installed one of their small beacon vertical tops along with the SB II on our 185 recently and I would do it again in a heartbeat. This is what the install looks like
pilotryan wrote:I have really enjoyed reading this thread today! You have a beautiful airplane that will be even better once your vision for it is complete. Please keep us posted on how it comes along!
I noticed that you said your fin cap was cracked. Thankfully you caught that before you went flying! I had a beacon fall off of my rental slowhawk three weeks ago because of a crack that I missed
colopilot wrote:...On another note, what's the group consensus on using a 6.00-6 main wheel with an 8.50-6 tire? Goodyear's tire guide recommends 8.50-6 wheels, however it does seem like people are managing to use the 6.00 as well. I'm not finding anything conclusive so far.
robw56 wrote:colopilot wrote:...On another note, what's the group consensus on using a 6.00-6 main wheel with an 8.50-6 tire? Goodyear's tire guide recommends 8.50-6 wheels, however it does seem like people are managing to use the 6.00 as well. I'm not finding anything conclusive so far.
I’m not sure what you’re trying to say? 6.00-6, 7.00-6, 8.00-6, 8.50-6, 26” Goodyears, and 26” through 31” Bushwheels all use 6 inch wheels.
jaudette wrote:I think you're going to love that prop! I've put about 20 hours on the new carbon prop on my RV-7 and absolutely love it! It's smoother, less vibration and throttle response is instantaneous! The icing on the cake is that it's 8kts faster! If I could hang one of those on my Franklin, I would!
P.S. You ought to come over and fly the RV. It's not an apples to apples comparison, but smoothness and throttle response will be similar.
colopilot wrote:.....Tomorrow I'll move the remaining Nav head over to create two vertically-aligned spots for the CGR-30 combo being ordered this week....
hotrod180 wrote:Sounds like things are coming together for all the work to happen!
I'm curious as to the "two vertically aligned spots" for your "GCR-30 combo".....
are you installing two of them?
colopilot wrote: The "might as well's" are what are really dragging this on, it's impossible to take on something like this and not want to improve everything else that you find at the same time. There are things I will just have to go back and do later or it'll never end.....
hotrod180 wrote:Aircraft upgrades can be a slippery slope.
I've seen some people slide down that slope until they run out of money....
unfortunately, sometimes it's before the airplane is flyable again.
