Done so far: BAS harnesses, Plane Power alternator conversion, alternator and panel noise filters, Door Minders, right side door repair, new Knots2U seals on all doors and windows. New nose strut seal after it blew on my last landing before annual. We did some other maintenance work on the engine and fuel system, but that's wasted effort now.
Next up in this phase: O-520 P-Ponk conversion, new prop, new mount, new engine controls. All original wiring replaced with new, ground runs added, firewall battery conversion and new solenoids. All rubber fittings and hoses replaced with new. Replace/refurbish the entire fuel system (cells, sumps, senders, valve, etc). 406 ELT. I have to replace a couple tires, so debating doing the Airglas fork and going big at this point. I have a new-used transponder in a box found on BCP waiting to go in to replace the one that went out on my last flight. Some minor rewiring in the panel. Possibly a new Com antenna, or at least some repaired coax since Com2 turns to static once airspeed builds up (thinking a ground short caused by flex). One mother of a sign-off from my A&P.
Eventually: Sportsman STOL kit, Airglas fork if not done now, LED nav/anti-col lights all around to coincide with STOL kit's new tips, new panel hopefully using the Dynon HDX setup. Interior is dated but OK for the time being, it'll probably be the last thing to get done. Paint will either need touching up in several areas or a re-do, there are certain areas which look very nice (like the empennage) and others that have none, or need to be stripped and repainted. Previous owner was not exactly a pro with paintwork. I will probably just go a single base color and vinyl for the accents. Paint will come after the STOL kit as well. I'm sure I've forgotten some stuff here.
Good news is I can reuse my PP alternator on the 520, so the only thing I've wasted to date are some rod seals and cover gaskets on the engine, a case of oil my A&P poured in, and a fuel filler neck gasket. I just (like last 10 hours) put new Lord mounts on the engine, but I'm guessing I can resell those and take a lesser hit at least on the parts. We were all done with the annual minus the engine problems, so once the 520 is in and tested out I should be able to reset the annual clock with minimal expense. At least my A&P knows it isn't going anywhere.
Progress this weekend... Carb still on as I apparently cannot shut off the fuel at the valve, so I need to cap the strainer outlet until I can drain the tanks into something. I also had wiring insulation behind the engine crack and fall apart when I flexed it, exposing bare wire. You can probably imagine how those two things can go badly with each other. I need to replace one of the fuel cells anyway, so at this point I am just going to change anything flexible and fuel related, and any wiring that hasn't been recently replaced - so changing out most of it.
With the systems refurb now being more of an urgent thing, it's going to take a good bit longer to get it in the air than I was hoping. At least I will know and trust the condition of everything though.
