L18C-95 wrote:The straight tail, trimmable stabiliser 182 is such an excellent all rounder - it may be on this thread, but am assuming useable fuel is 55 USG, or do you plan to fit either the rear baggage tank or new wing tanks?
colopilot wrote:The rear baggage option did look interesting, what I didn't like was the reduction in effective door opening since it sits higher, at least as far as I know. It could make using the baggage space a bit more challenging. I try to keep my flights in the 3-3.5hr range as well, though I have occasionally gone over that dodging weather. Still, I hit my personal limits around that point too. We'll see how it all works out once it's flying again. With the old engine I planned 12gph and that netted me 4 hours with 30 min reserve. The burn will be higher on the 520 naturally, but also covering more distance in that time so we'll see how it averages out. I'm changing so much on this plane that I won't hazard a guess, it will take flight testing of speed vs fuel burn to determine what best cruise (speed) and best economy (distance per gallon used) end up.
jaudette wrote:Put'em in dude. We just wrapped up mine today. It's a big install; but in all my days of flying I never felt like I had too much fuel. Especially flying around in the sticks!
Of course, it's easy to spend your money...
jaudette wrote:We all need sponsors....
colopilot wrote:L18C-95 wrote:The straight tail, trimmable stabiliser 182 is such an excellent all rounder - it may be on this thread, but am assuming useable fuel is 55 USG, or do you plan to fit either the rear baggage tank or new wing tanks?
Yep I have the standard 55 usable on board. I'm going to wait to see what the burn and range look like with this new engine before deciding any next steps. If I do anything it'll be flint tip tanks, so I am pre-wiring for those gauges and pumps while I have things apart in case I add them later.
Barnstormer wrote:In the meantime you might consider carrying fuel bags and using them when needed. 5 gal each and when empty they take up almost no room, and don't weigh much. I carry a couple in the SQ2 for long legs (at 90mph), like Tok to Whitehorse- never needed them but nice to have in case of a strong headwind.
http://www.airframesalaska.com/Liquid-Containment-Bag-p/5.2bag.htm
colopilot wrote:jaudette wrote:We all need sponsors....
And a support group. Aviators Anonymous, a 12-step program for convincing yourself this isn't a problem.
What's your panel kit Aeropod? Have one for a 206?AEROPOD wrote:Email me your N number and serial number and I can set you up with the paperwork for the panel kit.
[email protected]
