My 182 has an O-470-L. The oil pressure at startup registers just at the bottom of the green, roughly 30 psi. By the time it gets warm it drops back to 10-15psi and will stay there with minimal change throughout MP/RPM settings. Although my engine has higher calendar time, it only has 300 since a no name overhaul. My last two oil changes haven’t shown any metal and my temps aren’t out of the ordinary. I’m running Aeroshell 20/50. We have hooked a secondary pressure gauge into the system to confirm it isn’t the sending unit or gauge itself. We also blew out the line to the sending unit to ensure no debris. The case and engine compartment are dry and overall it doesn’t burn much oil, maybe a quart every 6 hrs.
Any insights as to what might be causing this or what we can do to remedy the issue?
