in 14 CFR § 91.113:
Converging. When aircraft of the same category are converging at approximately the same altitude (except head-on, or nearly so), the aircraft to the other's right has the right-of-way. If the aircraft are of different categories—
(1) A balloon has the right-of-way over any other category of aircraft;
(2) A glider has the right-of-way over powered aircraft.
(3) An airship has the right-of-way over all other powered aircraft, except for an aircraft towing or refueling other aircraft.
(4) An aircraft towing or refueling other aircraft has the right-of-way over all other powered aircraft.[/b]
8GCBC wrote:I hope all involved submitted an Aviation Safety Reporting System form (ASRS). The dude in the airplane is at fault from what I can tell.in 14 CFR § 91.113:
mtv wrote:8GCBC wrote:I hope all involved submitted an Aviation Safety Reporting System form (ASRS). The dude in the airplane is at fault from what I can tell.in 14 CFR § 91.113:
This was in Austria, so FARs don't apply. That said, hopefully the local regulatory entity is looking into this.
That said, the paraglider was below the airplane, and it looked like the plane was coming right at it. Would have been REALLY hard/impossible to see below the nose.
Maybe. Just glad everyone survived. Good news is, that lady has one HELL of a story, complete with video to back it up.
8GCBC wrote:mtv wrote:8GCBC wrote:I hope all involved submitted an Aviation Safety Reporting System form (ASRS). The dude in the airplane is at fault from what I can tell.in 14 CFR § 91.113:
Are you implying the powered aircraft can run down gliders and get away with it in Austria?
Flyhound wrote:When flying along a mountain chain on the windward side, I tend to stay far away from the rocks to avoid hang gliders and paragliders playing in the ridge lift. This paraglider might have been flying cross country, and that would make the incident a little more understandable. The "wings" on these things tend to be made from bright colors, so they aren't that hard to spot. I suspect the paraglider will be replacing all of their flying strings due to the abrasion inevitable from such an encounter. I wonder if any noticeable damage was done to the plane?
mtv wrote:Flyhound wrote:When flying along a mountain chain on the windward side, I tend to stay far away from the rocks to avoid hang gliders and paragliders playing in the ridge lift. This paraglider might have been flying cross country, and that would make the incident a little more understandable. The "wings" on these things tend to be made from bright colors, so they aren't that hard to spot. I suspect the paraglider will be replacing all of their flying strings due to the abrasion inevitable from such an encounter. I wonder if any noticeable damage was done to the plane?
There's a map of the paraglider's flight, and yes, she had covered a LOT of territory.
