Backcountry Pilot • Raising the flaps after landing
93 posts • Page 5 of 5 • 1, 2, 3, 4, 5
Re: Raising the flaps after landing
I have to distinctly different approaches that i use regularly:
Short field: 50 mph on final, flare, yoke in my lap don't touch the flaps.
Passenger impresser: 60 mph on final, grease the mains, hold the nose off and let it settle as speed bleeds off and simultaneously retract flaps.
Jeredp offline
Aircraft: Cessna 172
My general plan is go from full flaps to one notch when the wheels touch so I'm ready for the go around. If its a one way in no go around spot I find my self trying to pull in more then full flaps to stop when the wheels hit. In fact I just about ripped out the Johnson bar a couple weeks ago landing on skis, trying to pull it back "need more drag... no brakes!"
I enjoy reading all the different posts and opinions on here I take many ideas and go test them my self to see if they will work for me in my plane.
Paul
N419A offline
Aircraft: 1953 Cessna 170B 180hp
1957 Piper PA-18 Super Cub
contactflying wrote:Rob56- Are you related to the Rob who is a cropduster in Yuma? Most of my rough flying was spraying. The only 500 footers in a Pawnee was on steep hillsides. Lots of big rocks though. That was seeding, so not so heavy. I flew straight parathion in five gallon buckets to my Pawnee in my TriPacer quite a bit. Lots of forty acre fields used for spray strips. Lots of off field precautionary landings on the pipeline in bad weather. I would lay up and wait.
In the picture it looks like you were pretty slow, full flaps, and I expect the water slowed you a bit. I think you were hover taxiing a bit over the water. I hope so. I bet you didn't try that Vx stuff on takeoff. Ground effect is good stuff, and free. Slow is best on landing and fast on takeoff, however you do it. The apparent rate of closure approach just makes it so easy you can do it in your sleep. In the videos, I see guys putting the wing down quite a bit to make corners in rivers. That is dangerous. In ground (or water) effect, we don't want to put the wing down into something. Kids come back with crop in the booms doing that, if they are lucky. The airplane will make fifteen degree turns easy in ground effect. Just keep the wing level with aileron and drive around with rudder. Remember, ground effect is much more effective at three feet than at twenty, especially in a high wing. Six inches is best spraying and on takeoff.
I like how you never answer the question on using brakes on a 500ft runway. You're absolutely wrong saying if you use brakes you're going to fast. Myself and many others would never get to go to some of the places we go. I guess if you like 5000ft runways, no brakes are great!! Hopefully your wife comes back again soon to pull you back to reality!! Brakes are a must! Good day!
piperpainter offline
Aircraft: C-205
Was Backcountry Mooney M20C
Bryon- Of course you are right. I avoided 500' landing sites. I have landed and stopped many times in less than 500' with full flaps and no brakes in normal pipeline C-172s. Getting back out in 500' with a 150 hp 172 even down low and cool requires that you get the nose wheel off quickly and get the mains off quickly and stay in very low ground effect until maneuvering speed is attained. Even the barbed wire fence at the end of quarter mile strip is a bear.
The only thing I have against brakes is putting tailwheel airplanes on their nose and putting too much pressure on nose gears. It is just that I flew a lease Pawnee one season with no brakes and my old TriPacer, Champ, DC-65 Taylorcraft, and Luscombe just didn't have any effective brakes.
Why would you want to land so fast that you would need brakes in a place long enough to get back off? I'm not complaining, just asking.
Flaps???? We ain't got no stinking flaps!
Get over it, People. Get a REAL airplane. :lol: :D :lol:
piperpainter wrote:I like how you never answer the question on using brakes on a 500ft runway. You're absolutely wrong saying if you use brakes you're going to fast. Myself and many others would never get to go to some of the places we go. I guess if you like 5000ft runways, no brakes are great!! Hopefully your wife comes back again soon to pull you back to reality!! Brakes are a must! Good day!
I might chip in here... with a little gem of experience I gained a fortnight ago.
We landed on a certain airstrip for a day's fishing. I try to be precise, and was very pleased to pull up short without much difficulty, within about 1/3rd of the airstrip.Two persons and full fuel. Long grass helped to slow us down. Importantly, I did use a fair bit of brakes.
Some days later, we returned with a two friends and half fuel, it was early morning and a heavy dew was on the grass. I first inspected another nearby airstrip with better fishing which was quite a lot shorter, but we decided it wasn't wise to explore a new spot with 4 pax... it turned out to be a good decision.
When we returned and landed at the first airstrip, I wanted to park in the same place as last time, so started on the brakes as soon as the wheels hit the (wet!) grass. Both wheels locked up(!) without much resistance, and we promptly "slid" down about 3/4 of the airstrip as I tried to keep the wheels turning under brakes. That caught me by surprise. I was glad I had landed as slow and close to the threshold as I did, and that I started using what little braking action I had from the earliest possible point. That might have saved me from running off the end.
Another vote for leaving the flaps down. I find I can land any type plane on any surface, including asphalt, shorter using a combination of aerodynamic braking and light wheel braking vs dumping flaps and abusing the brakes.
Here is the detail that is glossed over in all this debate: Flying in the backcountry, by definition we are landing on soft, rough surfaces. Why would you want to dump all the weight on the wheels and start plowing furrows at 40 or 60 knots? Are you trying to break your wheels off? Let them roll.
Sooner or later, all you flap-dumpers will land somewhere without any braking action, and slide into the puckerbrush.
elgoatropo offline
This guy is loud and obnoxious like me. I like him.
i'v got a book that is about a canadian bush pilot. and he would check the ground by NOT landing and just let the wheel's run the surface to make sure it was hard then land... if you land and dump flaps on a condition unknown surface you might just plow in and be stuck [-X
ExperimentalAviator offline
That's called "dragging" the surface and I would say it is not part of the landing process but instead part of the decision to land process. I'd compare dumping flaps while dragging to getting out of the airplane on short final.
kind of like the cubcrafters S2 that was stuck anyone have that pic to show
CamTom, it was not meant to be dump the flaps dragging, it was meant to be don't dump the flaps on the ground roll the moment of touchdown...sorry
Ah, gotcha. Makes more sense that way!
