I'm going to jump in here and spew my $.02!!
I have a couple of hours in a 206 going into some very rough places, a few of the rougher ones are not strips of any kind.
First flaps hold the tail up when you are slow! Nose wheel breaks if on the ground!
Just 1 little story and I think there are about 6 folks I know of on here who know how to fly a 206 in the rough!!
I don't think any of them have chimed in!!
Per the the question of the original post.
I was flying a well known football player wild life tv guy and his kid and there tv guys into the braided parts on the Bering river below the Bering Glacier from a nice lodge on Cape Suckling, I flew in with their guide to see where we were going, Really big rocks and really soft!!
Went home and put the 29"s on the mains! This is our old 64 206 with 300 hp and the elevator extension. I did not want to use the really shiny ones we had!! And this is the lightest of the 4.
Left Cape Suckling loaded to the gills 1 guy and a whole load, Now I can tell you this was worth my while!!$$$
If the nose wheel is on the ground while I'm landing I'm going to need a helo to get out! Just the way it was. Big gravel and cobbles.
Now I can tell you, you can come in with full flaps Steep approach (REAL SLOW) and with the electric flaps and hit the up and also get to the ground when they are just shy of fully up, now when you do this you have to be almost full throttle when you touch down Yoke all the way back And the whole Idea is to use as much brake and throttle to stop and to keep the tail down until you are stopped,cause if you put the nose wheel down it will break off along with the prop. Soft gravel with cobbles up to 10"s
This is an area 350' long with river at one end and a 10' cut bank at the other. This landing is done and you have used up maybe 250" of your area, unload.
Taxi with the tail down to the river real straight and then shut down and have your guy help you turn the plane around. He was on the tail helping you keep the nose off.
Now for the take off, Now here you don't screw around and worry about your prop!! As you slam the throttle to the stop you hit the flaps down and hold the front tire just high enough to keep it out of the rocks, when you come off the bank you have full flaps, you settle back into ground effect and as you head down the river you milk the flaps up and head back for the second of 4 loads in, just repeat! Your adding just the amount of fuel you used each flight!!
Now it's 10 days later and your here to take everything back out, Well I made 12 trips out of there with about 300lbs each trip, I hauled everything but the people, I had a friend come in with his cub and haul the live cargo out to a big bar a few miles away.
Had fun, was on the edge of my seat, spent some nice time at the lodge, got paid way to much money and made one hell of a tip!
Customer got a show out of it and I got paid, was lucky and did not break anything, could I do that right now? Absolutely not!! I'm not flying 1500 hours a year in a 206 and into the rough like I was then!!
Can you get in shorter by dumping the flaps on landing, Damn right in a 206 you can, and I'm pretty sure you could in a 182 and also the front tire on a 182 will fall off much easier than a 206, Keep it off the ground when it's rough! You can't do that to a stop with the flaps down.
Also you won't learn how to do this at Riidle or any other flight school!! They don't know how!!!
Is it smart to do it, Hey that's for you to answer!!
Is it worth it? It was for me!
Just don't say you can't just because you haven't done it, or know how to!!
