mtv wrote:Apparently, you failed to actually read my comments. That's fine, do as you will.
Next time you see one of those Cessna's with 8.50 x 10s on the mains and an 8.50 x 6 on the nose, consider that this implies the nose tire is in fact a smaller size than the mains, which is my point.
And yes it is possible to land mains first with the nose wheel held off.
If you do so, I strongly suggest that you install a tail skid under your aft fuselage, because at some point you might get just a bit too enthusistic holding that nose wheel off, and push your tail cone up into your rudder.
Oh, I know.....you're such an ace you'd never do that. I watched a 25,000 hour air taxi pilot do so, which convinced me that I was capable of doing so.
Nobody on here is that clumsy, however...
Whatever suits you is fine with me...
No Mike I read your comments!
Now you have changed your argument from running a smaller than originally specified in the STC 8.50X6 nose wheel. To running bigger mains. 8.50x10 or even 29's???
Also now your argument is that you have to run a tail skid???
Changed from the 8.50 being hard on your firewall??
Maybe you didn't read the topic!
The whole point of the FM revision is that now you can use smaller than 8.50x6 on the nose.
NOT larger than 8.50's on the mains!I said that in my opinion the 8.50 was less stressful on the nose gear than a smaller tire.
I stand by that.
On smooth surfaces it doesn't matter but on the rough surfaces it matters a lot!
Not everyone needs the 8.50 on the nose. That is up to the individual to decide what suits his/her mission the best. If a 7.00 or 8.00 is desired then the STC revision opens up new possibilities for owners. That's great!
The smaller tire is lighter, steers easier especially on pavement and is cheaper!
I run an 8.50x6 on the nose and 8.50 X10's on my 205 and I run 29's on my 207.
The reason I use the bigger mains is for more flotation on the sand and to smooth out the roughness a little.
If the 8.50x10's or the 29's were not available I would be running 8.50x6's all the way around.
People look to this site to get information about flying, maintenance, mods etc.
Posting that if someone runs 8.50's all the way around they will damage their nose gear or their tail cone....
Well that is simply untrue!
