I don't know what your current engine situation is but here is one with everything on it that you could just bold on and fly for a while and then rebuild.
http://alaskaslist.com/1/posts/10_Trans ... ngine.html
ak2711c wrote:I had my IO-360C off of my plane doing some maintence today and decided to weigh it as well. This weight includes, mags, harness, plugs, alternator, starter, oil filter adapter, governor, baffling, spinner backing plate, oil cooler, Rieff preheat system, 6 CHT probes, fuel lines, fuel flow transducer and air cleaner. No motor mount, no exhaust, no vac pump and no oil. Weighed with a digital scale using a load cell to hang the motor from. It weighed 335 lbs.
whee wrote:...I can't figure out what he is talking about. Anyone have any ideas? The starter adapter for the IO360 is very different than that on the 470 or 520 so that can't be it.
whee wrote:I've been searching for a way to install a rear mounted belt driven alternator on my IO360
chetharris wrote:Whee,
They make a stater adapter that drives a pulley for an alternator and all of the brackets for the tcm io-360. TCM part number for the starter adapter assembly: 653074A39. Do not know if this link will work: http://www.tcmlink.com/Webgrph/37_126.gif. It is a pic of the assembly.
Probably as rare as hens teeth and quite expensive.
I have always thought the direct drive made more sense. Why add brackets and pulleys and belts to the system? Never had a significant problem with my direct drive alternator.
Chet
hotrod180 wrote:As I recall, the accessory case of an IO360 is (kinda) like that of an O300D.
90 degree starter adapter, gear-driven alternator.
What's wrong with the standard alternator set-up?
chetharris wrote:I have always thought the direct drive made more sense. Why add brackets and pulleys and belts to the system?
Zzz wrote: I have to admit, the belt driven alternator and the external flywheel/ring gear are 2 of the advantages to a Lycoming in my opinion. Simple, and keeps the accessory case less prone to cascading failure and contamination with explodered gear chunks.
