First Wee, I appreciate your gathering this information in one place.
I think the heavy, hump backed case is makes sense.
I am skeptical on the crank. I am particularly skeptical of Continental's data on this. If you have not read the AVWEB article by Mike Busch entitled "Who Benefits from Airworthiness Directives?", I recommend it:
http://www.avweb.com/news/atis/184427-1.html .
The article suggests Continental makes some interesting claims, but the Aeronautical Repair Station Association (ARSA) says not all of the data was presented or considered. Arsa teamed up with the Aircraft Owners and Pilots Association, the Cessna Pilots Association, and the National Air Transportation Association and analyzed the FAA's Service Difficulty Report (SDR) database as well as their own repair data. Below is a quotation directly from the article relating what the combined groups found.
"They also pointed out that the FAA elected to ignore its own SDR database (which did not support the need for the proposed AD), and also ignored the analysis submitted by ARSA in February, 1994. ARSA's analysis was based on the results of ultrasonic testing of crankshafts required by AD 87-23-08 by TCM-authorized inspection facilities throughout the U.S. The ARSA data showed that companies had detected 27 subsurface fatigue failures out of 3,821 airmelt crankshafts subjected to ultrasonic test, for a failure rate of .707%, and had detected 5 failures out of 488 VAR cranks tested, for a failure rate of 1.025%. ARSA pointed out that these failure rates are statistically equivalent.
Furthermore, the joint Association response points out that the FAA's own supplemental notice 'exhibits a lack of confidence in the superiority of VAR crankshafts.' The proposed AD requires that VAR crankshafts undergo ultrasonic testing at every removal, so that 'clearly the FAA recognizes that VAR crankshafts are subject to the same unsafe condition as airmelt crankshafts. The FAA has offered no evidence to conclude that unsafe conditions exist in airmelt crankshafts that do not exist in VAR crankshafts. The two types of crankshafts should be treated in a comparable fashion.' "
I have read that the long term analysis shows that the airmelt cranks ended up failing less often than the VAR cranks. I do not have a source for that claim. If I was experimental, I might consider running the airmelt, but I would want to confirm reliability reports and not just Continental's claims.
Chet
