I'd carry the 9mm with 20 rounds of hard cast. You didn't mention which model Elite, but if it's a long barrel model that'd be really nice. Keep the semi-compact loaded with anti personnel rounds.
Just me.
asa wrote:Hammer, what 10mm round would you recommenced for hopefully not shooting a bear in AK? Also, what rounds would you recommend for practicing at the range for hopefully not shooting aforementioned bear? I'm a new (4 months ago) owner of a 10mm.
Hammer wrote:asa wrote:Hammer, what 10mm round would you recommenced for hopefully not shooting a bear in AK? Also, what rounds would you recommend for practicing at the range for hopefully not shooting aforementioned bear? I'm a new (4 months ago) owner of a 10mm.
What 10mm do you have?
For hopefully not shooting a bear I'd recommend two rounds: Underwood 200 grain hard cast or the Underwood 220 grain hard cast:
https://www.underwoodammo.com/collectio ... 5723908153
https://www.underwoodammo.com/collectio ... 5725055033
I had to put a heavier recoil spring in my Glock 20 to make the 220's function properly, which is not uncommon. It's an inexpensive and easy mod, btw. 200's worked with the stock spring, but the heavier spring kept the gun from getting battered so enthusiastically and I've never gone back to the stock spring, even for non-Hiroshima loads.
It's pretty important to run at least one full box through your gun and chosen magazine to verify function. I have three magazines that are ammo-particular...they'll run everything fine except one specific load. No idea why, but it's real prudent to test each load to each magazine. That gets expensive, so I generally test critical loads with one or two magazines and just stick with them for that application.
For practice I'd use one of the inexpensive, medium-power loads. Sellier&Bellot makes a good 180 grain round, as does Magtech. Those are the two "bargain" loads I've used that impressed me, though I'm sure there are others out there. The Underwood's recoil is stouter, but it's not worth a buck a shot to practice with them. It's not that big a difference from the shooters perspective. Load one or two Underwood loads randomly into a magazine of S&B, and you probably won't be able to tell which is which under rapid-fire practice.
BTW, Underwood recommends the Lehigh Defense bullets for bear defense...something I really disagree with. For starters I don't believe Lehigh's claims about wound cavity are relevant in anything other than ballistic gelatin, and they don't penetrate nearly as deeply as the hard cast lead rounds. They're also a lot more expensive. Lose-lose from my perspective.
If it's available in your area, go to a USPSA shooting event. They can be a lot of fun, and the pressure of shooting against the clock, for a score, with an audience, will teach you a lot more about shooting for keeps than punching paper or perforating soup cans ever will. It's not the same as being charged by a bear, but it's amazing how many people who fancy themselves reasonable gunslingers go to pieces at the starting BEEP of the timer.
Have fun!
whee wrote:My Elite 9mm is the 4.5" barrel.
whee wrote:…..I really don't think I have it in me to shoot a person so I don't know why I'd want to keep any of the guns loaded with rounds for that purpose......
soaringhiggy wrote:some of those folk scare the crap out of me. I do not know what has caused the shift in society but it is apparent.
Hammer wrote:Whee,
I felt bad for your conundrum, so in the spirit of solidarity I went out and bought another 10mm yesterday. I've got your back like that...unless we're charged by a bear, in which case I'm climbing a tree.
