I flew my plane home from a very expensive annual (corrosion found starting under the floor, entire floor had to be removed) yesterday.
<200 hr Pponk, MT 2 blade prop, Sky-tec starter.
When I went to fire it up it turned over a couple times then just... stopped. It felt like a hard stop so I immediately turned it off and shut the master off. I thought about it for a minute and decided to get out and see it the prop would turn by hand. It turned forward and backward without any hesitation so I figured I might have experienced a kickback (per Motoadve's long thread) so I gave it another try to see if the starter would work. It turned a few times and fired normally. I taxied over to the fuel dock, added fuel, and it started again without incident.
Today I went to go for a flight and it turned over once then definitely hit a hard stop. I shut down and got out and it would not pull through by hand. I called my mechanic and he asked if it would pull backwards. It would go about 1/8 turn, then stop again. The prop was in exactly the worst position to use the tow bar so I tried wiggling it a bit in both directions and lo and behold, it pulled through at least half a turn before it stopped again. My mechanic asked me to remove the starter and it came off cleanly with no apparent damage to the starter. The prop would not turn freely at this point, just half a turn before hitting a stop that required a bit of jiggling before I could get another half turn. He asked if I could see the adapter gear turning when I turned the prop and it was not turning.
At that point he said it seems to be the starter adapter and told me to put the cowling back on and he would come take a look this afternoon or Monday. I'm looking for some advice and knowledge so I can ask good questions.
If it is the starter adapter, is that potentially catastrophic? In Motoadve's thread there was some talk about starter pieces floating around in the engine.
Again, if the starter adapter, does that require pulling the engine? I'm tied down outside and do not have access to a heater hangar and the mechanic is a couple hours away. Not an ideal setup for a visiting mechanic.
Any shared knowledge appreciated.
