Super Cub: Small, cramped, uncomfortable little plane manufactured originally by Piper, most have been remanufactured several times by various other people.
Piper took the light weight, trainer/sport plane and put a larger engine on it and the "Super" badge, thus making a bush plane. The Super cub is the best STOL certified plane out there, it's about the worst plane in every other category.
Piper wisely put low cross braces on the top of the cockpit to discourage large pilots. I say wisely because the flap lever is positioned in front of the left edge of the seat, preventing large pilots from using left aileron with flaps extended.
Super Cubs are also notorious for inspiring stupidity in their pilots. They apparently create an overwhelming urge to try landing on tiny ridge tops or stream beds. This frequently results in the Cub demonstrating it's ability to land and park inverted. The Cub then tries to beat some sense into it's pilot by rapping his noggin on the afore mentioned cross braces. However, this typically fails and the pilot just compounds his stupidity by adding longer gear, bigger tires, VG's, bigger engines and various other devices to increase the planes weight and capacity to inspire stupidity.
This also results in a high rate of AIDS (Airplane Induced Divorce Syndrome) among Super Cub owners, since the house has to be mortgaged to pay for remanufacturing and modifying the Super Cub.
You get the picture.
Phil
