ington6 wrote:why would you go flint over monarch? Just wondering... Not sure how much the flint tips weigh but for someone that wants to keep the plane really light, 54 lbs is a bit much. Already fattening her up with SPW mount and 26" ABW.
The Flint tanks for a 182 slide inside the wing tip. Pull the tip and outboard rib, slide in the tank, plumb the line and electrics for the pumps to the fuselage, and go fly.
I don't know what they weigh, but it's waaaay less than that quoted to you for the Monarch tanks. That seems heavy to me, but those roto-molded tanks are pretty heavy.
The reason I suggested the Flint tanks is because you balked at the Monarch tanks due to weight, and I for one would NEVER put one of those Javelin tanks in an airplane I owned. Personal preference.
I may be wrong on the Flint tanks being available for the 182. There are three types of Flint tip tanks:
The originals, which are as I described above. Slide INSIDE the outboard rib bay of each wing.
There is a model which replaces the wing tips on the Cessna 206, and attach to that mounting. They actually extend the wing the length of the tank, and on the 206, they increase gross weight by 200 pounds.
Then there is a newer model for the 185 and ???, which actually extends the wing structure and the tank goes inside the wing extension. Flint tried to get the same thing as the 206 kit approved on the 185 and FAA said no way.
According to Flint's website:
https://flintaero.com/kits/internal-tip-tanks/ the original style tank that slides inside the tip is available for the 182.
I ran these on my 170 and they worked fine. Might be perfect, but I never had any complaints.
