CamTom12 wrote:…..Especially in carbureted engines, fuel/air mixture isn't perfectly balanced across all cylinders. With only a single EGT you might accidentally lean one or more cylinders into a less than optimal scenario (see here:
https://www.savvyaviation.com/wp-conten ... ed-fin.pdf).....
Kinda what I'm getting at with my comments.
That Bush article is a good one, but even he says that it's esp hard to achieve even EGT temps with the O-470, due to the intake system.
As he says-- LOP is good, ROP is OK, peak is bad.
If you're leaning an O-470 by the numbers, using a multi-point EGT gauge,
it's likely pretty hard to get one or more cylinders to LOP without at least one of the others being at peak.
I think I prefer to conservatively lean the old school way, as per the quote in my previous post--
I'd rather burn a little extra fuel or sacrifice a little horsepower,
than take a chance on damaging my engine.
