Aryana wrote:That was a special order option, so I'd understand. [emoji16]
Only on the experimental version.
***NOTE**** We do not offer an experimental version of the CGR-30P. The reply was only meant in jest.
In response to the adapter harness, it would adapt the UBG-16's EGT and CHT probes/harnesses to the CGR-30P's EDC-33P middle connector. As such, no new probes and cables would need to be installed. The system would also utilize the existing fuel flow transducer, but a new harness would need to be run from the EDC to the flow transducer.
