Installed Elevator Gap seals.
(invisible)
Cuffed wrote:I fly a plane that originally had the windshield seated in felt but someone decided to bed it in silicone. The squeaking never stops while taxiing or in turbulence. Annoying. Anyone else find this?
Felix wrote:Hey Asa - this project is looking amazing. Appreciate you taking the time and effort to bring us along.
Question: you mentioned earlier that you invested in some tools for your wiring. What would you say were the best bang for the buck investments you made in that area? I have a couple of projects coming up that I am dreading, but having some nice, shiny tools might help make me a convert to the fun that can be had rewiring an airplane.
asa wrote:Felix wrote:Hey Asa - this project is looking amazing. Appreciate you taking the time and effort to bring us along.
Thanks Alex!
You can for sure conquer the wiring. My biggest resource (other than 43.13-1B) was SteinAir.com. They're a company that does mostly experimental custom panels but also sell everything they use on their online store. They also have an amazingly helpful YouTube channel with videos ranging from wire size intros to terminating shields to crimping coax. Everything you need. In those videos they outline what tools they prefer/recommend and normally they support buying mid grade tools. For example they recommend the $40 Dsub crimper instead of the $450 one.
I bought the tools individually and I haven't added up the prices but this kit encompasses what you would need to do what I did.
https://www.steinair.com/product/panel- ... -tool-kit/
You likely will not need the molex crimpers unless you are adding in connectors for ease of serviceability later. You also would only need the Dsub extractors and crimper if you're doing Dsub connectors (radio, intercom, transponder).
The wire strippers, ratching crimper, and a nice (not used for safety wire and such) set of flush cut snips are the items you would want for sure.
https://www.steinair.com/product/automa ... -stripper/
https://www.steinair.com/product/ratche ... rame-only/
https://www.steinair.com/product/flush-cutters/
I had a digital heat gun due to using oratex, but man is it nice to have for wiring.
SteinAir also sells all the milspec wiring and such, and are super helpful on the phone.
Mapleflt wrote:On word; inspirational, on every level. Your skills, abilities and dedication to the process has been a pleasure to watch and enjoy. I thank you for taking us all on this adventure through your posted photos and commentary.
mobileandmonitoring wrote:I will echo the previous statements. Thank you for sharing your build. So cool to see it come along. I could really use patrol windows on mine. Are you putting in the new style door locks?
If you ever need a free shop hand/visitor I'm just sitting here in AK waiting on summer
G44 wrote:Niiiiiiice! Keep going! Feb 28 is closer than you think!
Question…. Why do the Maule seats break or deform? Weak spot down in the attach area?
gdflys wrote:G44 wrote:Niiiiiiice! Keep going! Feb 28 is closer than you think!
Here's a few reasons that I can think of. First the seats are a simple steel tubing frame with fiberglass seat pan and back topped with foam and upholstry. The tubing doesn't have a good gusset or doublers at the corners where the seat pan and seat back frames meet. This is often an area of repair and added reinforcements after the first repair. Also the seat back fiberglass extends above the tops of the steel tube frame. So the fiberglass can end up breaking off above the frame. Both weak points are put to the test because Maules are not the easiest planes to get in and out of. People often end up supporting a lot of their weight by pushing on the tops of the seat backs while climbing in or out and trying to fold their legs into the smallish door opening. Of course that exerts the max amount of leverage on these weak points. Repeat that every time someone gets in and out and the seats eventually crack and fail. I try to have anyone getting in mine use the exposed tubing in the skylight area to lift themselves up while getting in or out instead of pushing on the seat backs. But even after repeated lessons they often still use the seat back method since some find it ergonomically easier.
