Backcountry Pilot • The Big Cessna 180 / 185 Empty Weight Thread
123 postsPage 2 of 71, 2, 3, 4, 5 ... 7
Re: The Big Cessna 180 / 185 Empty Weight Thread
aktahoe1 wrote:1734 on 31's, WingX, Sportsman, Pponk, MT, Titanium gear, sling seat and more. It's accurate Image
Good shot of a '53 flap :wink:
Rob offline
The paperwork on my 1954 180 says 1573.8. We will be weighing it shortly after an extensive revamp and paint. My Super Space Ranger Estimating Guesstimator says I'm pretty likely to end up with a better excuse for not flying with the corpulent in-laws again...
flyingzebra offline
1973 180J.
Weighed last week on certified scales.
1924 with rear seats and Aerocet cargo pod installed, CG of 36.35. 3,190 gross.
1865 lbs without pod or middle row seats, CG of 35.28.
I think I need to shave some weight with a different propeller :wink: Let's see what the missus says...
Mods/weight piggies are:
Cargo pod,
Firewall battery,
Fishing rod tube,
Factory extended baggage,
Factory float kit,
Ski points,
PPonk gear beef,
Heavy starter,
850-6’s (standard tailwheel),
3-blade McCauley,
185 tail,
autopilot,
IFR panel,
Horton STOL,
VG’s,
BAS handles,
Jump seats in middle row (non-folding Cessna types), no rear seats,
Shoulder harnesses front & middle,
LR tanks.
Timbuk2 offline
Aircraft: Cessna 180 Skywagon
Legend AL18 Supercub
1980 180K, weighed 5 years ago at Beegles and no mods since then. Very close to a stock 180.
Weighs 1798 empty, or 1780 if I take out the rear seats. I have the 3190 GW mod so useful load is around 1400 lbs or ~860 after I fill the tanks. But it's a pig at that weight.
slowmover offline
slowmover wrote:1980 180K, weighed 5 years ago at Beegles and no mods since then. Very close to a stock 180.
I've always wondered how a 230 hp 180 would perform at 3190 lbs. There's a very noticeable difference in what mine will do between 2400 and 2800 lbs. I can't imagine being pleased with the short field and climb performance nearly 400 lbs beyond 2800.
Scolopax offline
Just goes to show you that "useful load" doesn't tell the whole story.
Seems like as years went by & the empty weight went up, Cessna increased the gross weight to maintain the same useful load.
Big difference between how a 2550# airplane and a 2800# or 3150# airplane flies, behind the same 230hp.
1733 lb Empty, to go WingX, Vg's, AB 29". I figure its a little heavy because its a float plane and it has Monarch mains/aux's.
Gunny offline
That's a great looking Wagon, Gunny!
robw56 wrote:That's a great looking Wagon, Gunny!
Aw, shucks. Thanks!
gunny
Gunny offline
The latest amendment on my '54 180 puts it at 1518. Stock airframe, standard tanks, original lighter gear, basic VFR, rear bush seats, 6:00 tires. Includes the deletion of the vacuum system, gyros, ADF. Still has the heavy battery in the tail. 0470A with 88" C203 McCauley seaplane prop. Accurate? Who knows.
upnorth180 offline
Aircraft: '54 C180
'65 C185
‘54 BE18
BE18 (floats)
upnorth180 wrote: The latest amendment on my '54 180 puts it at 1518. Stock airframe, standard tanks, original lighter gear, basic VFR, rear bush seats, 6:00 tires. Includes the deletion of the vacuum system, gyros, ADF. Still has the heavy battery in the tail. 0470A with 88" C203 McCauley seaplane prop. Accurate? Who knows. ....
It's probably not far off...and I'm jealous.
You've got the recipe down pat for a lightweight 180:
early model, stripped down some, A engine, minimal radios, no heavy mods.
The only thing that might be heavier than stock is the 88" prop, and that's only a couple pounds worth.
Matter of fact, if you replaced an old threaded-hub prop, the C203 is actually lighter- maybe a lot lighter.
FWIW mine has the firewall mounted Odyssey battery, according to the W&B records that knocked off 19 pounds.
The firewall battery is on my list as well, but I'm waiting until I need to change the battery anyway since it was new when I bought the plane. I will be doing the Airglass flat floor extended baggage at the same time.
Once my Whelen LED strobes arrive, that will be enough for this year after doing the floats, interior and panel already this winter.
upnorth180 offline
Aircraft: '54 C180
'65 C185
‘54 BE18
BE18 (floats)
upnorth180 wrote:The firewall battery is on my list as well, but I'm waiting until I need to change the battery anyway since it was new when I bought the plane. I will be doing the Airglass flat floor extended baggage at the same time.
Scratch the question. I read your post. Haha. Man that's a sweet looking 180. Thanks for the DG by the way.
Right on. My single favorite combination mod for a 180. Firewall battery and flat floor. Even more important where it's cold.
fiftynineSC offline
Aircraft: Cessna 185F
Thanks. Finished up the last of the required mtce for the time being this morning, outside in the snowstorm.
Hope that DG serves you well.
upnorth180 offline
Aircraft: '54 C180
'65 C185
‘54 BE18
BE18 (floats)
Mine was weighed a couple years back as equipped at 1661 lbs on the standard Cessna wheel gear and 1984 on EDO 2960s. This is with Wing-X extensions, STOL cuff, and minimal VFR equipment.
Fraser Farmer offline
Aircraft: 1977 Cessna 185
Just got my 185 a new W&B this morning. A lot of you know how highly modded it is so I won't go down the list, but I will add that it's IFR equipped, STEC autopilot, 26 Goodyears and XP Mod tail wheel. She weighs 1,901.42 empty which gives me a useful load of 1,623.58. I can carry some of the 180's here. [emoji51] With full fuel and oil I have 1,137.58 for people and baggage. Sic! Very pleased.
Barnstormer offline
The Green Hornet - last weighed officially when leaving the factory in 1956.
1649.2 with atlees dodge rear jump seats installed
1636.2 without rear seats.
BAS tail pull and seat belt, xp mods tailwheel, 8.50 mccauley double pucks, door stewards, light battery rear mount, ack 406 elt, remote oil filter, 82" mac c66 prop, madras droop wing tip, atlee dodge rear jump seats, whelen strobes, knisley exhaust with the donkey dick
Old panel:
[url=https://flic.kr/p/TTw3fY]Image
New Panel, done just end of march - look at all that crap replaced by the EI CGR-30P:
[url=https://flic.kr/p/UtvTTD]Image
soyAnarchisto wrote:The Green Hornet - last weighed officially when leaving the factory in 1956.
Old panel:
Nice!
soyAnarchisto wrote:....knisley exhaust with the donkey dick...
Ha!
Nice job on the panel BTW.
