TOA-Cub wrote:You can probably restore your own to just as good for a whole lot less. I'd be leery of the "Just like new" claim, replacing all the skins is excessive. You can tell from the ED on Cessnas that the skin doesn't carry much load. I'm sure they will find and fix corrosion, but my concern with old aircraft is fatigue. Fatigue is in the frames, not the skins. I'd be curious as to what they are doing to the existing frames to extend the fatigue life. "Reconditioned/PMA replaced structure" is pretty vague. Are they reinforcing fatigued areas or just polishing and re-priming and replacing what's missing or they can't fix.
There is no "frame" for Cessna's - they are semi-monocoque aircraft so the skins are not for just keeping you warm - they are part of the structural strength of the aircraft - if you were to replace 100% of the skins on a Cessna - you would go a long way towards having a new structure, and would certainly have access to fix any rib, bulkhead, or spar that needed it.
Also the statement that you could restore your own for just as good for a whole lot less is very doubtful. For one - its a certified airplane so unless you are an A&P and then later an AI for all the sign offs - no you could not restore it yourself. To do what he is doing - you would need Cessna Jigs, and he is not just talking about replacing the skins - he is also talking about new engine, prop, garmin glass panel, bunch of STC. Every bolt, every cable, every gasket, every skin, every bearing, every hose, every fairing, every spring, every seal. Anyone that maintains a Cessna 170/180 know how ridiculously expensive some some of the new/refurbished things are (airbox anyone?) -
Titanium Gear legs w/ Alaska 29 bushwheels, titanium axles, titanium stinger and saddle, new tailwheel fork, tailwheel head - that is 30 grand right there
I'm not promoting him, and I don't know anything about this guy - but alot of your post is just not accurate.
