Hey all,
Had a little issue with the plane the other day. A quick backstory: When I bought the plane (Aeronca Champ 7AC with a continental A-65) in April and was flying it from FL to Northern NY we had a carburetor issue in SC and had to make a forced landing. Long story short, we sent the carb out to get re-built and when it was reunited with the plane we flew it home with no issues. Since that time I have put around 45 hours on the plane and it has run flawlessly. Since we are 40 miles from the nearest airport with 100LL I have been using a mixture of 100LL when I can get it and ethanol free 91 octane when I can't. More car gas than 100LL. A week or so ago I noticed that when starting hot I had some fuel dripping out of the airbox. Chalked it up to a flooded engine, even though it had not happened before. Saturday I went out for a flight and the plane started a little hard, but it was the coldest I have tried to start it - around 40 degrees. Once it warmed up it ran fine and the run-up was normal. Took off and climbed out just fine. A couple minutes into the flight the tone of the engine changed and I immediately nosed over and headed back to the airport. It was not making full power and wouldn't pull redline even in a slight descent. Landed with no issue, and shut down. Took a look and there was fuel dripping pout of the airbox again. Ran the prop backwards as if I was trying to get a flooded engine cleared and it made a squishing sound and would shoot fuel out of the carb on every turn. Called the guy that re-built it ( who is a older guy with a ton of experience with these) and after describing what happened he asked me what kind of gas I was using. After some discussion he said it was from using car gas and to drain the tanks, and carb then run it with 100LL from now on and everything will be fine. I have no reason to not believe him, however it's pretty unforgiving around here and to be honest I am a bit nervous about firing the thing up and taking off, even if I run it on the ground for a bit. Do any of you have experience with this? If so any information would be appreciated.
Thanks,
Pete
