hotrod180 wrote:Although some people could fuck up a steel ball with a rubber hammer, <snips>
"Balance marks are placed on many tubes to indicate the heavy spot of the tube. These marks are often paint stripes about 1/2 inch (1 cm) wide by 2 inches (5 cm) long. When a tube is installed, this balance mark must be aligned with the "light spot" balance mark of the tire (red dot). If the tube has no balance mark, place tube valve adjacent to the tire balance mark (red dot).
formandfunction wrote:It's entirely possible I could have been too ruff on the first one but don't recall any ruff landings on it.
88H wrote:FandF:
I run the Desser 8.50 x 6 on my 180 and have had good luck with all. Not experienced what you have.
One thing you might consider. I have sent to Desser my old carcasses and had them recap them. I think the recaps are actually an improvement over the factory and they are slightly cheaper.
Good luck!!
OutbackMaule wrote:A long time ago and at an airport far far away I was working as a green A&P at a small shop. We would often get complaints of nosewheel shimmy on various Cessnas. Being green, I followed the book and rebuilt dampeners, replaced bushings etc, often to no avail. The owner of the shop had been in aviation since the 1920s and finally clued me in to his method for curing tire shimmy. Remove the wheel and clean and dry the bearings. Reinstall on the axle with the bearings loose. The tire would rotate to a position with the heavy spot down. Tape a rectangular piece of an old inner tube to the outside of the tire. Fiddle with sizes until the tire is balanced. Mark the position and disassemble the tire/wheel. Using contact cement, glue the piece of tube to the inside of the tire. Re-assemble. I don't remember this method ever not working.
